1202 Transponder Squawk Code - In a Tow Plane?
Old May 31st 18, 06:48 PM posted to rec.aviation.soaring
kirk.stant
Default 1202 Transponder Squawk Code - In a Tow Plane?
All three of our towplanes have unique ATC assigned (by letter) squawks, to be used when actively towing gliders.
Transponder-equipped private gliders use the standard 1202 code.
Kirk
SLSA
Old May 31st 18, 07:11 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Kirk
SLSA
Kirk - So those are permanently assigned squawks? How did you go about that?
Old June 1st 18, 06:20 PM posted to rec.aviation.soaring
kirk.stant
On Thursday, May 31, 2018 at 1:11:14 PM UTC-5, OHM Ω
We have several members in the FAA or who work closely with the FAA. I assume they coordinated with our TRACON to establish the individual unique codes for each of our 2 Pawnees and Supercub. We have a letter on file with the codes, which are only to be used when actively towing gliders.
Kirk
Old May 31st 18, 09:59 PM posted to rec.aviation.soaring
RV 6 Driver
Kirk
SLSA
Correction Kirk SLSA only has 2 towplanes...
Old June 1st 18, 05:55 PM posted to rec.aviation.soaring
kirk.stant
Kirk
SLSA
Ha ha. Inside joke, folks...
66
New Transponder Code (1202) for Gliders (Effective Feb 9, 2012) CLewis95 Soaring 14 May 25th 11 11:09 PM
New Transponder Code (1202) for Gliders (Effective Feb 9, 2012) 5Z Soaring 2 May 25th 11 11:02 PM
Transponder squawk code 1201 approved for ZDV Frank Whiteley Soaring 0 June 7th 10 08:00 PM
New Nationwide Squawk Code Fred[_5_] Soaring 53 April 9th 10 10:02 PM
squawk code 2000 Gordy Instrument Flight Rules 2 March 14th 07 11:21 PM
