Digital altimeters
Old June 3rd 18, 06:26 AM posted to rec.aviation.soaring
Ross[_3_]
Default Digital altimeters
Why not simply go to Air Avionics?
It is a fully TSO altimeter.
https://www.air-avionics.com/
Enjoy
Old June 3rd 18, 07:05 AM posted to rec.aviation.soaring
2G
Enjoy
The ACD-57 is about twice the price of the MGL and lacks an ASI.
Tom
Old June 3rd 18, 09:08 AM
Skypilot Skypilot is offline
Member
First recorded activity by AviationBanter: Feb 2012
I just bought a SZD55 with a digital altimeter and a LX9000. First thing I did was put a new Winter 57mm altimeter in it. Main reason was insurance payout is you break it outlanding, second reason was it looks awful and is hard to read.
Just my thoughts.
Enjoy
Tom
Old June 3rd 18, 05:34 PM posted to rec.aviation.soaring
Enjoy
Tom
It may be more expensive than the MGL unit but the fully certified AIR display (including altimeter activation fee) is slightly cheaper than a Winter altimeter - and there is the option of using the display to also control a compatible radio and transponder all from one 57mm hole.
Old June 3rd 18, 05:58 PM posted to rec.aviation.soaring
2G
Enjoy
Tom
Which would be attractive if you have, as I do, a certified glider. Being certified, however, does not necessarily mean the instrument will be better, more reliable, more accurate, etc. The digital altimeter is, most likely, more reliable and accurate than the certified mechanical altimeter.
Tom
Old June 3rd 18, 08:22 PM posted to rec.aviation.soaring
Use caution with the Air Avionics transponder if you need ADSB out. Last time I checked their transponder is not capable of a SIL-1 or SIL-3 level output.
Old June 3rd 18, 08:49 PM posted to rec.aviation.soaring
Trig will not share communication code with AIRAvionics therefore ACD-57 will not operate a Trig COM or XPDR.
IMO, the 57mm Winter altimeter is a waste of money and panel space.The MGL Vega instruments are said to have good visibility in bright sunlight. I think it is worth a try but first would like to see one powered. Maybe at Oshkosh.
Old June 3rd 18, 10:16 PM posted to rec.aviation.soaring
jfitch
A marketing decision by Trig and in my opinion a bad one. The ACD-57 will control a Becker radio, and better than Becker's own front end. Surely it would be better than the Trig too, if Trig would only see the light.
I have altitude from the Air Vario, the CN Vario, the Trig, the iPhone, the inReach, and finally the Winter steam gage. It would be nice to get rid of the steam gage.
Old June 3rd 18, 10:33 PM posted to rec.aviation.soaring
Dan Marotta
So...Â* You're never really quite sure of your actual altitude then. Or
do they all say the same thing?
Dan, 5J
Old June 3rd 18, 03:28 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Enjoy
http://www.craggyaero.com/acd_altimeter.htm
I have one in my Glider and I have them in stock.
Richard
www.craggyaero.com
Setting altimeters with no radio Mxsmanic Piloting 178 November 15th 06 08:35 PM
Any 2.25 in, sensitive altimeters (3 pointer)? rpellicciotti Home Built 2 July 14th 06 04:57 AM
Thunderbirds and Altimeters Dudley Henriques Military Aviation 17 February 1st 04 06:00 PM
Thunderbirds and Altimeters Dudley Henriques Naval Aviation 9 January 29th 04 05:48 PM
wristwatch altimeters [email protected] Aviation Marketplace 2 December 6th 03 01:22 AM
