Digital altimeters
Old June 3rd 18, 02:13 PM posted to rec.aviation.soaring
Default Digital altimeters
On Saturday, June 2, 2018 at 2:13:38 PM UTC-7, wrote:
Tried of the 57mm Winter altimeter being too inaccurate even after being re-calibrated. Being EXPERIMENTAL, going to look into digital.
Going to look at MGL Vega ASV-1 first as it displays altitude and airspeed. http://www.mglavionics.com/html/vega_color_singles.html
Anyone had experience with this specific make/model?
Its hard to find specific guidance for instruments in experimental gliders within the maze of FAA regulations, but as a practical matter, I found my Winter compact altimeter calibration was inadequate for safely flying close to restricted airspace, even after factory recalibration, so I took it out and use my CAI and LX altimeters, which have excellent calibration.
Old June 3rd 18, 05:01 PM posted to rec.aviation.soaring
JS[_5_]
I use a calibrated Winter 57mm altimeter and regularly fly near or in Restricted airspace. The ALT display in the TT22 is a more important thing there..
Old June 3rd 18, 05:12 PM posted to rec.aviation.soaring
Dan Marotta
Isn't the altitude display in the TT22 corrected to 29.92" Hg?
During wave flights and high thermal days, I use local field altimeter
setting on the baro altimeter.Â* At 17,900' MSL indicated I generally see
about 17.7 on the Trig.Â* I do NOT push up to 17.9 on the Trig given my
pressure altimeter will read around 18,200'.Â* I just don't need that
extra altitude at the risk of a call/letter/visit from FSDO.
Dan, 5J
Old June 3rd 18, 08:38 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
ATC sees only your Trig altitude , not your altimeter, never the less, probably prudent not to bust an IFR altitude with your calibrated altimeter.
Setting altimeters with no radio Mxsmanic Piloting 178 November 15th 06 08:35 PM
Any 2.25 in, sensitive altimeters (3 pointer)? rpellicciotti Home Built 2 July 14th 06 04:57 AM
Thunderbirds and Altimeters Dudley Henriques Military Aviation 17 February 1st 04 06:00 PM
Thunderbirds and Altimeters Dudley Henriques Naval Aviation 9 January 29th 04 05:48 PM
wristwatch altimeters [email protected] Aviation Marketplace 2 December 6th 03 01:22 AM
