Digital altimeters
Old June 3rd 18, 05:12 PM posted to rec.aviation.soaring
Dan Marotta
Default Digital altimeters
Isn't the altitude display in the TT22 corrected to 29.92" Hg?
During wave flights and high thermal days, I use local field altimeter
setting on the baro altimeter.Â* At 17,900' MSL indicated I generally see
about 17.7 on the Trig.Â* I do NOT push up to 17.9 on the Trig given my
pressure altimeter will read around 18,200'.Â* I just don't need that
extra altitude at the risk of a call/letter/visit from FSDO.
On 6/3/2018 10:01 AM, JS wrote:
On Sunday, June 3, 2018 at 6:13:25 AM UTC-7, wrote:
On Saturday, June 2, 2018 at 2:13:38 PM UTC-7, wrote:
Tried of the 57mm Winter altimeter being too inaccurate even after being re-calibrated. Being EXPERIMENTAL, going to look into digital.
Going to look at MGL Vega ASV-1 first as it displays altitude and airspeed. http://www.mglavionics.com/html/vega_color_singles.html
Anyone had experience with this specific make/model?
Its hard to find specific guidance for instruments in experimental gliders within the maze of FAA regulations, but as a practical matter, I found my Winter compact altimeter calibration was inadequate for safely flying close to restricted airspace, even after factory recalibration, so I took it out and use my CAI and LX altimeters, which have excellent calibration.
I use a calibrated Winter 57mm altimeter and regularly fly near or in Restricted airspace. The ALT display in the TT22 is a more important thing there.
Dan, 5J
Old June 3rd 18, 05:34 PM posted to rec.aviation.soaring
On Sunday, June 3, 2018 at 7:05:10 AM UTC+1, 2G wrote:
On Saturday, June 2, 2018 at 10:26:53 PM UTC-7, Ross wrote:
Why not simply go to Air Avionics?
It is a fully TSO altimeter.
https://www.air-avionics.com/
Enjoy
The ACD-57 is about twice the price of the MGL and lacks an ASI.
Tom
It may be more expensive than the MGL unit but the fully certified AIR display (including altimeter activation fee) is slightly cheaper than a Winter altimeter - and there is the option of using the display to also control a compatible radio and transponder all from one 57mm hole.
Old June 3rd 18, 05:58 PM posted to rec.aviation.soaring
2G
Enjoy
Tom
Which would be attractive if you have, as I do, a certified glider. Being certified, however, does not necessarily mean the instrument will be better, more reliable, more accurate, etc. The digital altimeter is, most likely, more reliable and accurate than the certified mechanical altimeter.
Tom
Old June 3rd 18, 08:22 PM posted to rec.aviation.soaring
Use caution with the Air Avionics transponder if you need ADSB out. Last time I checked their transponder is not capable of a SIL-1 or SIL-3 level output.
Old June 3rd 18, 08:38 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
ATC sees only your Trig altitude , not your altimeter, never the less, probably prudent not to bust an IFR altitude with your calibrated altimeter.
Old June 3rd 18, 08:49 PM posted to rec.aviation.soaring
Trig will not share communication code with AIRAvionics therefore ACD-57 will not operate a Trig COM or XPDR.
IMO, the 57mm Winter altimeter is a waste of money and panel space.The MGL Vega instruments are said to have good visibility in bright sunlight. I think it is worth a try but first would like to see one powered. Maybe at Oshkosh.
Old June 3rd 18, 10:16 PM posted to rec.aviation.soaring
jfitch
A marketing decision by Trig and in my opinion a bad one. The ACD-57 will control a Becker radio, and better than Becker's own front end. Surely it would be better than the Trig too, if Trig would only see the light.
I have altitude from the Air Vario, the CN Vario, the Trig, the iPhone, the inReach, and finally the Winter steam gage. It would be nice to get rid of the steam gage.
Old June 3rd 18, 10:33 PM posted to rec.aviation.soaring
Dan Marotta
So...Â* You're never really quite sure of your actual altitude then. Or
do they all say the same thing?
Dan, 5J
Setting altimeters with no radio Mxsmanic Piloting 178 November 15th 06 08:35 PM
Any 2.25 in, sensitive altimeters (3 pointer)? rpellicciotti Home Built 2 July 14th 06 04:57 AM
Thunderbirds and Altimeters Dudley Henriques Military Aviation 17 February 1st 04 06:00 PM
Thunderbirds and Altimeters Dudley Henriques Naval Aviation 9 January 29th 04 05:48 PM
wristwatch altimeters [email protected] Aviation Marketplace 2 December 6th 03 01:22 AM
