So what happens if I rent a welding cylinder, weld until it's empty, remove the regulator, forget to close the valve, and just for fun it gets rained on?
Do they just refill it or dry and purge it first? |
On Sunday, June 3, 2018 at 9:14:57 PM UTC-7, wrote:
So what happens if I rent a welding cylinder, weld until it's empty, remove the regulator, forget to close the valve, and just for fun it gets rained on? Do they just refill it or dry and purge it first? If folks who rely on that cylinder find out the back of you head might hurt :-) I would ask your specific supplier. Many places will get more cautions with cylinders that have no pressure in them, simple purging at a minimum. if the cylinder was suspected of containing water the fill station can fully dry it and if they want wan to internally inspect it or fully test it. Remember the cylinders are fully wet internally when hydrotested... but they are dried and purged before refilling. If you abuse a cylinder and it causes serious internal damage I hope that is found in time by the next cylinder test, in the internal or ultrasound inspection or pressure test. |
So what happens if I rent a welding cylinder, weld until it's empty, remove the regulator, forget to close the valve, and just for fun it gets rained on? Do they just refill it or dry and purge it first? My experience is that it varies. But I have had suppliers who insisted on a vacuum purge (and associated cost) when presented with any completely depressurized bottle. The last time I built a bottle from scratch (medical D plus aviation CGA540 valve), I purged it myself using my vacuum bagging pump, put about 100 PSI of O2 in it from the welding rig, and then took it to the refill place and got it filled, no problem. --Bob K. |
Every welding O2 supply house I have been to exchange the cylinder, not re-fill it. It is just so much faster for a welder that needs to get back on the job. This exchange would be only for standard sizes. This may be fine for your glider but in my particular case (Schleicher) I haven't found a welding supply house yet that has the correct (exchange) size for my sleeve. Most glider operations out west can refill for you. You might try medical supply houses.
On Monday, June 4, 2018 at 5:58:37 AM UTC-7, OHM Ω http://aviation.derosaweb.net wrote:
Every welding O2 supply house I have been to exchange the cylinder, not re-fill it. It is just so much faster for a welder that needs to get back on the job. This exchange would be only for standard sizes. This may be fine for your glider but in my particular case (Schleicher) I haven't found a welding supply house yet that has the correct (exchange) size for my sleeve.. Most glider operations out west can refill for you. You might try medical supply houses. I was meaning a standard cylinder that you then transfill into the glider cylinder. Yes the OP may not have an easy or safe way to carry the cylinder that, but that's how some folks without other options do this. No I would not carry a cylinder around in a car. Many gas suppliers will fill your own non-rental cylinders as long as the inspection is current and they are properly labeled. Some will hydrotesr/recertify out of date cylinders and then fill them. Anything labeled medical or aviators breathing oxygen increases chances it won't get filled as regular industrial oxygen. The discussion above already covered why you don't say the word "medical". |
Mountain High has a discussion on their FAQ page regarding different sources/types of Oxygen and confirms that it is all the same.
As others have stated, the best solution is to rent a bottle locally and return it when you leave. May be prudent to call ahead and reserve one. Having two aircraft bottles works well. Swap out full for empty and refill at your leisure. Also concur that large high pressure oxidizer bottles and transfill systems need to be treated with much respect. |
Road ID - must have | Ben[_6_] | Soaring | 11 | February 19th 15 03:22 AM |
Seen beside road | George | Aviation Photos | 15 | October 17th 07 09:45 PM |
One for the road. | Laonork | Piloting | 2 | April 27th 05 11:30 PM |
looking for consumer review on, um, range extender bottles | Paul kgyy | Piloting | 19 | February 24th 05 02:50 AM |
USA Roads alternate Road Textures, Not looking like a road map | Simulators | 1 | June 27th 04 10:08 PM |
