Towplane-Baron accident
Old June 6th 18, 04:52 AM posted to rec.aviation.soaring
2G
Default Towplane-Baron accident
On Tuesday, June 5, 2018 at 7:53:01 PM UTC-7, John Foster wrote:
On Saturday, February 22, 2014 at 7:50:49 PM UTC-7, Jp Stewart wrote:
Odd circumstance: http://www.lagrangenews.com/news/hom...llaway-Airport
JP
A question that has come to mind that I haven't seen discussed yet is one of visibility. How is a civilian airport even allowed to operate where two intersecting runways are in place where you can't see one from the other? I'm no expert here, but that just sounds like a disaster waiting to happen (which it did, in this case). Also (not a radio expert here) is the CTAF one that needs "line of sight" for the signal to be transmitted, or can the radio waves bend around land obstructions? Could it be that the land that obscures the view of the end of the other intersecting runway, could also obscure the transmission of radio waves, thus explaining why no one at the FBO or that both aircraft didn't hear each other's radio transmissions?
Radio communications are not 100% reliable. Pilots may be on the wrong frequency, have the squelch turned up, the volume down or step on each other. If you want to be sure, you must receive an affirmative reply. This was not done in this case, with tragic results.
Tom
Cessna 170 for a towplane? Scott Alexander[_2_] Soaring 9 April 30th 12 06:57 PM
Have towplane will travel Tim Gundersen Soaring 0 June 30th 11 07:13 PM
Pik-27 towplane Brad[_2_] Soaring 2 March 10th 09 12:01 AM
Towplane accident at The Dalles, Oregon Stewart Kissel Soaring 24 September 20th 04 07:20 PM
C 172XP Towplane Thomas F. Dixon Soaring 3 March 14th 04 08:02 PM
