Electric Self Launch System
Old June 8th 18, 09:50 PM posted to rec.aviation.soaring
Emir Sherbi
Default Electric Self Launch System
El viernes, 8 de junio de 2018, 16:59:09 (UTC-3), 2G escribió:
On Friday, June 8, 2018 at 6:51:52 AM UTC-7, Emir Sherbi wrote:
El jueves, 7 de junio de 2018, 20:41:10 (UTC-3), 2G escribió:
On Monday, June 4, 2018 at 9:09:00 AM UTC-7, Emir Sherbi wrote:
Hi everyone,
My name is Emir Sherbi, i'm a mechanical engineer from Argentina. With a partner who is an electronic engineer we've designed an electric self launching system that can be retrofitted in most of the composite sailplanes. Some of you may be saw my booth in the SSA convention in Reno with the mockup of the prototype.
The idea is to sell it as a kit so you don't have to ship the glider to my country. The modifications to be made are very simple. Any repair shop have enough knowledge to do it.
These are the links for who are interested in following the project..
https://www.instagram.com/grasshoppersystem/
https://www.facebook.com/charlysierragolf/
Kindest Regards
When I stopped by your booth, you indicated that this system is still in development with much work left to be done. Is this accurate?
Tom
Hi Tom
The most difficult part that we are working on is the battery pack supplier and testing. In other hand we also are starting to build our own motors, not only for this application but also for another types of vehicles (mostly agricultural). But for the US clients we can supply any already known motor brand to power the kit.
As you can see on the pages that i shared, we are starting to work on the fuselage. The pylon is on its final revision for flight testing but we are still working on the batteries.
Regards
Which battery chemistry are you going to use?
Tom
INR and IMR, depending on the flight mission.
Regards
Old June 9th 18, 12:30 AM posted to rec.aviation.soaring
son_of_flubber
https://breazy.com/products/samsung-...50-25r-2500mah
INR 18650 2500mah Battery (2 Pack) - Samsung
20 amps of continous discharge, the Samsung 25r has been the go to battery for most vapers because of its authenticity and its transparent rating system. In terms of cell degradation the Samsung 25r has been a reliable source of power.
Old June 9th 18, 01:28 AM posted to rec.aviation.soaring
Flub, are you implying this project is vapor ware?
Old June 9th 18, 01:43 AM posted to rec.aviation.soaring
son_of_flubber
Not at all. I think it is brilliant that millions of vapers have volunteered to do rapid discharge testing of INR battery technology. And a mass market battery like this should benefit from manufacturing economies of scale and competition.
Old June 9th 18, 02:30 AM posted to rec.aviation.soaring
Interesting additional battery chemistry info.....
https://batterybro.com/blogs/18650-w...ally-explained
Old June 10th 18, 03:10 AM posted to rec.aviation.soaring
2G
On Friday, June 8, 2018 at 6:30:32 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
And here is a lot more detailed info:
http://batteryuniversity.com/learn/a...of_lithium_ion
While the safety of IMR and INR are good, they are not as good as LFP.
Tom
Old June 10th 18, 04:54 AM posted to rec.aviation.soaring
Emir Sherbi
Yes, they are very reliable and stable. They have very long life cycle. But the energy density is lower. For the same capacity you have to think in more than 60% of weight increase.
Old June 11th 18, 01:30 AM posted to rec.aviation.soaring
son_of_flubber
I'd be very happy to have something soon that could sustain 30 minutes of flight at best glide speed. Maybe I'd upgrade to self-launch later when higher energy density batteries become available, but maybe not.
The 'best' is the enemy of the 'good enough'.
Having learned my lesson with Betamax, I'm looking for the VHS of electric propulsion. My glider is 20 years old. There is a limit to how much I want to sink into it.
Old June 11th 18, 02:47 AM posted to rec.aviation.soaring
"I'm looking for the VHS of electric propulsion."
And we wonder why we're decades behind the Europeans...
Old June 11th 18, 03:49 AM posted to rec.aviation.soaring
Emir Sherbi
For our design, having only 30 minutes of sustained flight or selflaunch and having 1 hour of sustained flight is the same technological challenge.
The only thing that changes is the final price.
20 years old is like new, we are about to install it on a 35 years old Pegasus.
Electric Self Launching System Emir Sherbi Soaring 0 June 4th 18 04:54 PM
FES&electric system batteries krasw Soaring 33 February 25th 17 04:17 PM
ASW24 - electric valve system Norbert Gulczynski Soaring 1 January 25th 15 01:13 PM
Electric Duct Fan (EDF) Self-Launch Glider? CLewis95 Soaring 26 January 20th 11 06:27 PM
Electric self-launch sailplane CH Soaring 2 September 14th 03 01:49 AM
