Cobra trailer stuck closed
Old June 9th 18, 02:28 PM posted to rec.aviation.soaring
Default Cobra trailer stuck closed
With zero pressure in the struts, you've got to lift the whole weight of the top and it's heavier than hell! I used a block and tackle from the shop roof. The rear handles were strong enough to take the load on a Komet..............Should be OK on a Cobra. Have 2X4's ready to prop it open and be carefull ..............its little more than a gilatine! Three man job, one on the hoist and two placing props.
Let us know how it worked out,
JJ
Old June 10th 18, 12:06 AM posted to rec.aviation.soaring
AS
It may be worse than that: If the piston seals failed but the rod seals held, all the gas pressure is now on the annulus or ring-side of the gas spring thus keeping the rod from extending swiftly. Applying up-pressure on the lid and then waiting may do the trick.
Good luck!
Uli
'AS'
Old June 10th 18, 02:21 AM posted to rec.aviation.soaring
Steve Koerner
Uh-oh, someone doesn't understand how gas springs work:
Good luck!
Uli
'AS'
Old June 10th 18, 04:22 AM posted to rec.aviation.soaring
AS
I do - I used to design similar devices....
Uli
'AS'
Old June 10th 18, 09:25 AM posted to rec.aviation.soaring
Jim White[_3_]
Uli
'AS'
It might help to unbolt the hinges and lift the lid evenly with two
winches?
Old June 10th 18, 01:22 PM posted to rec.aviation.soaring
Uli
'AS'
winches?
LAST resort only.
Putting top back on is a very big deal.
UH
Old June 10th 18, 05:46 PM posted to rec.aviation.soaring
Steve Koerner
Uli
'AS'
Well Uli let's talk gas springs for a moment...
If you actually did understand how gas springs work - the everyday gas springs used for car tailgates and glider canopies and Wing Riggers and Cobra trailers - then you would know what a silly suggestion that was. Gas springs already have a controlled leak across the piston. That is what establishes their wonderful damping property. Once stopped, there is no pressure differential across the piston at all. The nominal force produced by a gas spring does not relate to pressure across the area of it's piston (as is the case for a pneumatic drive cylinder); the gas spring force arises from the pressure exerted across the cross-sectional area of the rod itself.
Anyway, don't feel too bad about getting this wrong. I did a google search so that I could provide a link for you. Amazingly, virtually every little story that came up about how gas springs work on the internet was also wrong -- including the wikipedia article on gas springs and a bunch of youtubes on the subject. It wasn't until I downloaded a lengthy manufacturers catalog that I came upon actual sound science that tells the story correctly:
http://pdf.directindustry.com/pdf/di...57-175377.html
So back to the original poster's issue: You do not need to worry about pressure leaked to the wrong side of the piston and holding the clamshell down.. That is a red herring of the highest order.
Old June 11th 18, 05:14 AM posted to rec.aviation.soaring
Charlie Quebec
So younke-tbpooking until you found an answer that agreed with you, then ignored all other evidence?
Wanted to Buy : Ka-6CR Closed trailer Tango Juliet Soaring 0 January 5th 15 01:31 AM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Looking for closed trailer for ASK-21 or Grob-103 kirk.stant Soaring 0 September 23rd 12 06:26 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
WANTED (USA): Blanik L-23 Trailer (Open or Closed) CLewis95 Soaring 0 November 14th 08 09:23 PM
