LXNav Remote Stick Installation in a ASW 20B
Old June 15th 18, 02:31 AM posted to rec.aviation.soaring
Deming Gray
Default LXNav Remote Stick Installation in a ASW 20B
On Thursday, June 14, 2018 at 8:07:01 PM UTC-4, wrote:
Deming-
I installed a remote LXNAV stick controller in my Pegase a few years ago, and while I don't have the stick mounted trim trigger, I found no significant problem with feeding the wires down the tube and out the side hole in the stick. Otherwise, the ASW-20 is very similar to the Pegase. If there is any way to use a "pull wire" to guide the fairly thin 4 conductor wire in the proper path, I suggest you use it. Otherwise getting the new lead out the side hole can be challenging. Of course it could also be routed out the bottom of the stick if there is an opening in the U-Joint bracket, but you have to be careful that it cannot get pinched as the stick is manipulated through its full range of travel. If you are successful getting the wire out the normal side exit hole, try to add a piece of heat shrink tubing to the lead to minimize (or delay) abrasion caused by the wear point between the wire and the hole in the stick. Sometimes the edges of the hole are sharp enough to cut through the wire sheathing. Leave plenty of slack at the lower end where the wire exits so that no part of the wires are subjected to strain or sharp bends. Finally, leave about 6-12 inches of wire folded and tucked inside the upper portion of the control stick tubing. This allows the stick grip to be removed without putting strain on the wires. Plus, if you have to re-route the wires for any reason, you will have some length to work with. Connection of the remote stick's four wires to the LXNAV terminal is easy- just match the wire color to the appropriate socket, push the spring loaded tab and insert the wire. For a connection like this, I like to "tin" the ends of the multistrand wire with a drop of solder to minimize strand breakage.
Thanks Mark, I'm glad to hear that your installation of the LX remote stick went smoothly. That gives me some confidence. I appreciate the tip of leaving spare cable in the joystick and using heat shrink as protection for the cables.. I'll incorporate both of those ideas.
Old June 15th 18, 05:26 AM posted to rec.aviation.soaring
JohnO[_2_]
I have installed several remote stick controls onto LXNav equipment. SZD55, ASW24E, ASG29 and Ventus 2c. Some of these have a trim trigger incorporated and it does not present a problem. I particularly remember the SZD55 had the trim trigger wire going through the column and the wires from the controller just ran to one side and there was never a problem.
Be careful with leaving excess wire inside the stick!
I have had two installations were the wires from the LXNav control were bunched up near the top and managed to be trapped and damaged against the top of the stick. I now take the top plate and electronics out from the top of the handle and check the wire routing into the top of the control stick.
LxNav USB hub? Jonathan St. Cloud Soaring 8 May 21st 18 04:06 AM
Butterfly vario and remote control on the stick [email protected] Soaring 1 July 17th 17 07:04 PM
LS7 control stick diameter and LXNav remote stick Gianni Isotope Soaring 2 March 15th 17 02:36 PM
Help Needed: LXNAV S80 and Remote Stick grip ZP Soaring 18 January 29th 16 03:19 PM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
