THE LONG AWAITED BREAK THROUGH IN BATTERY TECHNOLOGY HAS BEEN FOUND
Old June 15th 18, 04:42 PM posted to rec.aviation.soaring
Charlie Quebec
Default THE LONG AWAITED BREAK THROUGH IN BATTERY TECHNOLOGY HAS BEEN FOUND
Something like this would be ok for a acceleration booster, even if only 20 seconds of high power to accelerate for self launch.
Given the FES motor has more power than the Fisher Top motor, with an acceleration boost, self launching at 400kg would be possible.
Old June 16th 18, 12:20 AM posted to rec.aviation.soaring
Dave Nadler
On Friday, June 15, 2018 at 9:42:35 AM UTC-6, Charlie Quebec wrote:
...even if only 20 seconds of high power to accelerate for self launch.
Nope, supercaps absolutely not helpful.
You need enough power for a safe climb rate for several minutes.
And that much power already provides more than adequate acceleration.
Forget the supercaps for this application!
BTW, some electronics I designed flying in produced gliders uses supercaps ;-)
Old June 16th 18, 01:16 AM posted to rec.aviation.soaring
Charlie Quebec
A FES motor would provide sufficient climb rate, and an initial boost would be helpful.
As I pointed out, it is already more powerful than a TOP motor.
Boeing HorizonX Invests in Advanced Battery Technology: unmatched energy density and reliability Larry Dighera Piloting 0 January 29th 18 05:14 PM
Found in a long-forgotten folder Byker Aviation Photos 0 March 20th 16 12:03 AM
Possible Breakthrough in Battery Technology Matt[_3_] Soaring 3 March 1st 12 08:35 PM
AOPA Expo, meeting JayB, getting stuck in Lancaster on the way home,fulfilling the commercial certificate long solo x-c...long Jack Allison Piloting 6 November 19th 06 02:31 AM
TEST PILOTS ACCOUNT OF INFLITE BREAK UP (SR 71) (LONG) caleb Owning 1 January 30th 06 05:01 AM
