New low budget two seater
Old June 15th 18, 09:14 PM posted to rec.aviation.soaring
Bob Kuykendall
Default New low budget two seater
On Friday, June 15, 2018 at 12:26:35 PM UTC-7, Paul Agnew wrote:
Meanwhile, the jigs for the Peregrine (Krosnos) are just sitting in shipping containers somewhere in Georgia. Could it be produced cost-effectively?
As I understand it, the problem with the Krosnos is that the engineering and certification are based on material specifications and thicknesses common in Europe but basically unobtanium here in the US. You'd need to either source all your materials from Europe, or re-engineer the aircraft to use US materials and thicknesses.
As a practical matter, it's not that hard. As a regulatory matter, however, it's a huge paperwork effort to go through every single blueprint and justify the change from some metric thickness to the nearest inch size. You basically have to re-engineer the entire structure.
Sourcing materials from Europe is a huge gamble. Here in the US there is a fairly fat supply pipeline supporting the homebuilt aircraft movement that currently produces the majority of all new general aviation aircraft. In Europe, the pipeline is a lot thinner and has a lot more friction and regulatory risk aversion, so it is likely that material costs would be a lot more.
Furthermore, given that prices for carbon fiber in terms of cost per unit mass and cost per unit stiffness are steadily declining, I think that carbon fiber is the way to go for any new design, even for a primary trainer.
Thanks, Bob K.
Old June 15th 18, 09:57 PM posted to rec.aviation.soaring
JS[_5_]
Another hurdle in producing the Puchatek / Krosno / Peregrine:
From memory, the existing 5000-hour limit never got to the point of having an inspection program for extension. This was to be worked on, but then Barry Aviation was awarded a contract that kept them quite busy.
The glider is a decent trainer: Roomy cockpit, good visibility, instruments front and rear, spin capable, aerotow or winch launching.
Thanks, Bob K.
Old June 16th 18, 01:20 AM posted to rec.aviation.soaring
Charlie Quebec
Never mind, one day the US will progress past the 19th century and use the metric system.
Old June 16th 18, 01:27 AM posted to rec.aviation.soaring
Frank Whiteley
Thanks, Bob K.
Yes, materials were part of the problem, Polish aluminum and Russian steel (not stamped but dated with a Sharpie), though Tim seemed to indicate substitution could be done. When surveyed, the majority of operators preferred metal over composites, but that survey is several years old now. Barry Aviation got as far as PMA and had set up the assembly line, but never achieved manufacturing certification. You have to be able to keep the lights on for a year or two at your manufacturing facility. Three have to be built under FAA observation in order to become self-certifying. If they don't like something, they leave and you will not see them again for months. Didn't seem to be a fix it and we'll come back when you're ready, we'll schedule a return when we're ready. In any event, the economy dumped in 2008 and they couldn't keep the facility open. Tim estimated a trained crew could build one per week.
Frank W
Old June 16th 18, 05:21 AM posted to rec.aviation.soaring
BobW
metric system.
Ha ha! Or maybe not. We (the US) built an early cruise missile you may be
familiar with; it was called "Snark."
We now build much better cruise missiles, though not metrically. I'm guessing
they have an engine-off L/D of around 10...as in 'somewhat less than' a 2-33.
Hence the engine assist, I guess.
Bob W.
This email has been checked for viruses by AVG.
https://www.avg.com
Old June 16th 18, 05:57 AM posted to rec.aviation.soaring
Charlie Quebec
Thats why we call the US Retardistan.
Old June 16th 18, 06:56 AM posted to rec.aviation.soaring
Jonathan St. Cloud
If I am not mistaken, Dick Johnson was a designer of cruise missiles.
  #28
Old June 16th 18, 03:22 PM posted to rec.aviation.soaring
Dan Marotta
Bob,
Would this be a production aircraft or a kit?
On 6/15/2018 12:48 PM, Bob Kuykendall wrote:
I've just started a Facebook page to discuss and promote the idea of an open-source crowd-sourced two-seat primary trainer certified as SLSA or whatever makes it eligible for commercial ride, instruction, and rental use. I envision something about halfway between the ASK13 and ASK21 in performance and complexity, and designed to fill in for the declining 2-33 population.
I'm not extremely optimistic about this effort, but as one of the few sailplane developers with a vested interest in the future of soaring in the US I thought I'd get the conversation going and see where it leads.
https://www.facebook.com/SoarOpenTrainer
--Bob K.
Dan, 5J
  #29
Old June 16th 18, 03:27 PM posted to rec.aviation.soaring
Dan Marotta
Where are from, Charlie Quebec?Â* One of the countries the US has been
supporting since 1945?Â* Time to grow up and take care of yourselves.
Dan, 5J
  #30
Old June 16th 18, 04:11 PM posted to rec.aviation.soaring
Jonathan St. Cloud
So I have learned that the Aussies call Americans sepptos - Yank - skeptic tank = sepptos: And I have learned that some our country calls us "Retardistan". Perhaps it is the company I keep, but I can't think of one derogatory term for another country or their people that in the lexicon Americans'. I guess when one has it all they don't feel the need to disparage another. Just a point on this aviation related site, America exports more aviation goods and technologies than any other country!
Spartan Three Seater pics 1 [13/13] - Spartan Three Seater vrt2.jpg (1/1) Miloch Aviation Photos 0 July 6th 17 02:52 PM
Spartan Three Seater pics 1 [12/13] - Spartan Three Seater vrt1.jpg (1/1) Miloch Aviation Photos 0 July 6th 17 02:52 PM
Spartan Three Seater pics 1 [10/13] - Spartan Three Seater VH-URB1.jpg (1/1) Miloch Aviation Photos 0 July 6th 17 02:52 PM
Spartan Three Seater pics 1 [09/13] - Spartan Three Seater line up 895-1.jpg (1/1) Miloch Aviation Photos 0 July 6th 17 02:52 PM
Spartan Three Seater pics 1 [08/13] - Spartan Three Seater jtaxi.jpg (1/1) Miloch Aviation Photos 0 July 6th 17 02:52 PM
