On Monday, June 18, 2018 at 7:19:13 PM UTC-4, wrote:
On Monday, June 18, 2018 at 2:07:10 PM UTC-7, wrote: That works really well as long as the transfer or release paper backing doesn't go soggy in water. Test first. UH The transfer paper *should* be waterproof enough to do what Mike O describes. I hang out at a place that does vinyl lettering and that is the technique they use. You're not soaking the surface or decal, just getting it damp enough to let it slide around as you place it. Also, it can take several days for the bubbles to completely go away - if you still have any. 5Z The 3M 7125 series material I use (intended for sign making and such)has a backing release paper that does not tolerate water. Other than that issue it is great. Thin, goes on easily, available in many colors. My point is simply check your materials before you go crazy. UH |
Applying Vinyl Contest numbers..... | Gary Adams | Soaring | 0 | May 11th 12 10:13 PM |
Removing vinyl letters | Gary[_5_] | Soaring | 7 | December 31st 11 06:10 PM |
vinyl trim source | Brad[_2_] | Soaring | 3 | March 23rd 10 05:02 AM |
Vinyl letters in foreign language | Fly | Home Built | 5 | December 6th 06 10:09 AM |
Plastic/Vinyl letters | Mel Dawson | Soaring | 23 | February 18th 06 11:46 PM |
