Vinyl Numbers
Old June 19th 18, 02:03 PM posted to rec.aviation.soaring
KEN
Default Vinyl Numbers
On Monday, June 18, 2018 at 11:33:03 AM UTC-4, wrote:
For years I've prepped the area by buffing to remove wax and contaminants, then centered the numbers and started in the middle. Just to find numerous bubbles trapped under the Vinal........Ugh!!! This morning I buffed the area to apply new COBRA decal to a trailer, wiped the area with a towel and was about to tape on the Vinyl when the low sun angle disclosed little lint balls everywhere! I had imparted a charge to the surface by buffing it. I gave it a few minutes to disparate, then wiped away everything with my hand and guess what? NO BUBBLES!
JJ
The material that you want to ask for is called air release vinyl. No need to use water. You can install dry with no air bubbles.
Applying Vinyl Contest numbers..... Gary Adams Soaring 0 May 11th 12 10:13 PM
Removing vinyl letters Gary[_5_] Soaring 7 December 31st 11 06:10 PM
vinyl trim source Brad[_2_] Soaring 3 March 23rd 10 05:02 AM
Vinyl letters in foreign language Fly Home Built 5 December 6th 06 10:09 AM
Plastic/Vinyl letters Mel Dawson Soaring 23 February 18th 06 11:46 PM
