Vinyl Numbers
Old June 19th 18, 04:14 PM posted to rec.aviation.soaring
Default Vinyl Numbers
Guess I didn't explain it too well, I believe the air bubbles are caused by lint on the surface. Check for lint with low light angle, then wipe surface with a painters tac-cloth before applying Vinyl.
JJ
Old June 19th 18, 08:02 PM posted to rec.aviation.soaring
Craig Funston[_3_]
JJ
JJ, you were perfectly clear. Thanks for the head's up.
The rest is just thread drift. Should we move on to PW-5s?
Cheers,
Craig
Old June 19th 18, 09:12 PM posted to rec.aviation.soaring
Wonder if a lint roller would be useful just before vinyl letter application...
Old June 19th 18, 11:03 PM posted to rec.aviation.soaring
I understood, the static can attract all sorts of crud from the air, even small flying insects. A damp wipedown can help kill the static as well as remove any final stuff on the surface.
A tack cloth can pull crud, but may do nothing about the charge.
Applying Vinyl Contest numbers..... Gary Adams Soaring 0 May 11th 12 10:13 PM
Removing vinyl letters Gary[_5_] Soaring 7 December 31st 11 06:10 PM
vinyl trim source Brad[_2_] Soaring 3 March 23rd 10 05:02 AM
Vinyl letters in foreign language Fly Home Built 5 December 6th 06 10:09 AM
Plastic/Vinyl letters Mel Dawson Soaring 23 February 18th 06 11:46 PM
