High Wing Planes are Better Than Low Wing Planes
Old June 19th 18, 11:25 PM posted to rec.aviation.piloting
Default High Wing Planes are Better Than Low Wing Planes
On Wednesday, June 13, 2018 at 1:01:04 PM UTC-4, wrote:
On Friday, May 25, 2018 at 8:00:20 PM UTC-4, wrote:
Comparing airplanes to birds is moot in this respect. You have birds achieving thrust by reshaping the wing by utilizing muscular structures in the body and planes achieving thrust without manipulating the wing.
If we assume that low wing is a better design, then birds would still be high wing because muscles achieve work by pulling, so flying would be impossible!
My initial point is that high-wing designs are inherently more stable
when moving through a dynamic atmosphere, and evolution proves it. We see
this in insects and bats as well. It's as simple as *not being top heavy*.
It's a gravitational factor.
Babbling nonsense.
Jim Pennino
Says you, the anal retentive dope who debates everything and
anything with non sequitur deflections and then finally after
trolling with a litany of insults, broken chains of thought
sequences, and non-deductive deductions, eventually just results
to lying, repeating misinformation ad nauseam, and packaging
the entire mess laden with grammatical errors that a fifth
grader wouldn't make.
Stay out of airplanes asshole.
**** off and die idiot.
Jim Pennino
Old October 29th 18, 03:05 AM posted to rec.aviation.piloting
John Huthmaker
Well thank goodness commercial airlines dont use low wing planes. I wouldnt want to travel in an inherently unstable death trap. Did I mention I fly Pipers because I like them much better than Cessnas?
Classic High wing Low wing collision user Soaring 1 May 17th 08 12:27 AM
Low wing landing, high wing taking off...oops [email protected] Piloting 1 May 16th 08 09:41 PM
Soft field landings - low wing vs high wing aircraft Justin Gombos Piloting 19 May 23rd 07 05:21 AM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
End of High wing low wing search for me dan Home Built 7 January 11th 04 10:57 AM
