A complicated question about LiFePO4 batteries, - and switching.
Old June 22nd 18, 12:12 AM posted to rec.aviation.soaring
SF
Default A complicated question about LiFePO4 batteries, - and switching.
I started off with two K2'S I charged RIPthem in parallel, discharged them in parallel. No issues. Then one of the cells died in one of the batteries. Ran them in parallel on the test rig current meters on both. The good battery ran the load until the voltage dropped and then the battery with the bad cell started sharing the load until I stopped the test when the voltage dropped under 11V. There was never current flow from one battery to the other. It was all 0 current or current supplied to the load.
Now running two starks in parallel, discharge and charge. No issues in 2 years now.
Fuses on each battery, separate switches for each, each battery's connection to the bus is also fused.
Don't need to make this complicated. But you can if you want to.
SF
Old June 22nd 18, 05:30 AM posted to rec.aviation.soaring
jfitch
SF
The way you would have a problem is if the batteries are in a very different state of charge when they are paralleled. If always charged and discharged in parallel, this can't happen under normal use. If one suddenly developed an internal short, then the other would dump current into it.
A Simple Question About LiFePO4 Batteries [email protected] Soaring 49 May 25th 18 04:27 PM
LiFePO4 Batteries on sale. [email protected] Soaring 20 December 9th 15 05:34 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
