On Fri, 22 Jun 2018 00:18:42 -0700, krasw wrote:
I would be very interested to know why this excellent feature cannot be found in any airplane. Because there are very few panel mount fuse holders available with built- in LED indicators? -- Martin | martin at Gregorie | gregorie dot org |
in LED indicators? How many do you want? https://www.ebay.com/sch/i.html?_fro...h+LED&_sacat=0 |
On Fri, 22 Jun 2018 06:22:27 -0700, markmocho53 wrote:
Because there are very few panel mount fuse holders available with built- in LED indicators? How many do you want? :-) I was curious, never having seen any, if indicator fuse holders were available So I did a bit of searching on the local electronics suppliers (RS, Farnell and Rapid Electronics) websites for individual LED indicator equipped 5 x 20mm fuse holders and didn't find any. I looked for that type because those would be direct replacements for the in-flight accessible fuse holders in my glider. I did see indicator fuse blocks and individual indicator holders for auto- type fuses and rather more with neon indicators, but none of the latter worked at 12v - they're all for 90-240v circuits. I'm somewhat surprised that LED indicator holders for 5x20mm fuses aren't available - it wouldn't be hard to fit an LED in the cap of these holders. -- Martin | martin at Gregorie | gregorie dot org |
Glass fuse holders are kind of 20th century aren't they? If you were replacing them, going to a circuit breaker which is both resettable and indicates that it has been tripped, might be the direction to go?
A Simple Question About LiFePO4 Batteries | [email protected] | Soaring | 49 | May 25th 18 04:27 PM |
LiFePO4 Batteries on sale. | [email protected] | Soaring | 20 | December 9th 15 05:34 PM |
K2 vs. StarkPower LiFePo4 batteries | Fox Two[_2_] | Soaring | 36 | April 16th 15 05:14 PM |
LiFePO4 Batteries | vontresc | Soaring | 56 | June 27th 14 07:25 PM |
LiFePO4 batteries | JS | Soaring | 26 | October 15th 12 02:51 PM |
