Libelle
Old June 24th 18, 09:11 AM posted to rec.aviation.soaring
Default Libelle
Contacted the Lancaster Airport on the off chance they still had the Libelle. Said it was in Canada now. I was offered a price of 1,500 on a Libelle that had a damage history. The known damage is a shattered canopy and a crushed leading edge in one wing approximately 3 inches deep and 3 inches wide from striking a tree or fence post. Unknown if there is any other damage to fuselage such as landing gear damage or boom damage. The pilot reported hearing "cracking in the wings" when he was upset by turbulence and became inverted in flight causing his head to strike and crack the canopy is what was reported to have happened. I'd really like to own a Libelle sailplane and thought maybe if I registered it as experimental I could have it repaired for a resonable cost. If it wasn't repairable it could be cosmetically brought back and would make a museum piece. Biggest problem I have is logistic of transport. I live in California and the ship is on the East Coast. I told the guy that I was probably gonna have to pass. If any of you know a good reason why I should pick this Libelle up and or could help me with getting it to California let me know. Thanks.
Old June 24th 18, 09:27 AM posted to rec.aviation.soaring
Default Libelle
Weird for me to specify the Libelle as sailplane? I'm making payments on a Viking Dragonfly and well... I thought maybe at 1,500 if the ship is damaged severely structurally I could remove all components such as water ballast system and control components selling those and the trailer donate the airframe as a static display model to an aircraft museum.
Old June 24th 18, 09:40 AM posted to rec.aviation.soaring
Default Libelle
Found a Libelle 301 for an asking of 8,000 that needs work but no damage history. It's my understanding that the 201 is preferable to the 301 though because of an improved airfoil, debatably materials not that balsa is bad, and better air brakes? Am I off base in this info? The 301 has flaps though as well no? I've seen a retrofit kit that improved the air brakes on another ship. Is that not possible on the Libelle too? Anyway I know a bit on these but not everything. To be honest I'd like to pay the 1,500 to just take the thing apart and see how it was made. I've never even seen one of these in person. I welcome comments, advice, and support. Thanks!
Old June 24th 18, 12:12 PM posted to rec.aviation.soaring
Charlie Quebec
Default Libelle
301 had flaps and better performance than 201.
Several mods available, Google Schumann Libelle.
Libelle 201 canopy [email protected] Soaring 0 July 4th 16 02:03 PM
Club Libelle H 205 POH James Anderson Soaring 1 August 1st 12 07:33 PM
Libelle Wings Steve Leonard Soaring 1 March 1st 07 07:27 PM
Libelle Wings Thermaler Soaring 3 March 1st 07 03:18 PM
Standard Libelle Pam Kurstjens Soaring 4 May 22nd 05 05:40 PM
