Stall, spin fatality today in Arizona.
Old June 24th 18, 03:37 PM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Default Stall, spin fatality today in Arizona.
Pilots should be thoroughly familiar with the slow speed turning behavior of their ships. Take a new ship to altitude and put it in a thermal type turn and then "abuse" the controls with skids, slips and too much back stick to see what it is going to do. Repeat this occasionally to remind you of the warning signs of incipient spins.
The Standard Cirrus wing twist (washout) was increased in 1972. Although earlier birds responded promptly to wing drop/spin they were (are) less tolerant of less-than-ideal pilotage than today's ships like the Duo Discus.
KS
On Saturday, June 23, 2018 at 6:52:48 PM UTC-4, Waveguru wrote:
Lost one of my best friends....
Boggs
Old June 24th 18, 05:16 PM posted to rec.aviation.soaring
Jonathan St. Cloud
KS
Boggs
Here is the best "Avoiding the Spin" video I have seen.
https://www.youtube.com/watch?v=JeI2LlEzOT4
Old June 24th 18, 06:16 PM posted to rec.aviation.soaring
glidergeek
Who was it Gary?
Old June 24th 18, 08:04 PM posted to rec.aviation.soaring
KS
I had an early Std Cirrus with the lesser washout in the early 80s and it was very prone to dropping a wing on take off and spun easily with wing drop.. Many years later a friend and I flew that same glider for a season and my friend fitted a top and bottom surface mylar aileron seal kit (from Glasfaser). Normally the top surface hinged ailerons only have top surface Tessa tape seals. I was doubtful whether it was going to be worth it but it turned out that the low speed handling was transformed for the better on take off and near the stall.
Old June 24th 18, 08:29 PM posted to rec.aviation.soaring
Waveguru
The family has been notified now. It was Andy Richenberger.
Boggs
Stall/spin and ground reference maneuvers Bill D Soaring 55 March 11th 14 04:35 PM
Improved shear/stall-spin alarms KiloKilo[_2_] Soaring 23 June 11th 13 11:55 PM
Another stall spin Jp Stewart Soaring 153 September 14th 12 07:25 PM
Stall/ Spin testing the RV-12 cavelamb himself[_4_] Home Built 3 May 14th 08 07:01 PM
