When gliders fail in flight, but pilots manage to land
Old June 24th 18, 05:27 PM posted to rec.aviation.soaring
Default When gliders fail in flight, but pilots manage to land
Good thoughts, thanks.
From what I remember, the most common "loss of a control surface" in flight are usually with glass ships.
-elevator not connected (more common on earlier ships before auto control connect)
-dirty connectors/dry lube in pushrod ball latches or on the ball itself
-failed gap seal safety tape (most common on the top of the elevator, sorta outta sight outta mind) that flips up when flying blanking the control
-a case where a ship was refurbished (2-33?) and cables were run backwards/crossed! Positive control check should make sure it's connected as well as going the anticipated way.
Positive control check helps a lot.
Crude "test" is to move controls quickly while watching them. If it is not connected, inertia may yield a clunk as the pushrod hits the ball. May.
Check safety tapes, replace as needed.
At least in the spring, clean control connect balls with a rag and WD-40 (decent safe solvent), lube the ball and locking mechanism.
After connecting a rod, try to lift it off near the ball. A slow/dirty lock may allow the rod to come off. Just had this a few weeks ago rigging a -21..
Everything you do on the ground, is one more way to avoid an issue in the air.
PS, the closest I have been (that I am aware of) to a control issue was a late day speed pass at home airport. In the pull-up, hit a gust that unlocked the dive brakes (-24) at a bit over 100MPH. Good for me, they didn't bend open, got them closed, cut pattern short, landed fine. Yes, we checked everything out throughly when derigging.
Training Materials for Pilots Transitioning to Tail Dragger Gliders? Papa3[_2_] Soaring 0 July 7th 13 02:03 PM
Pilots in India often fail alcohol tests Larry Dighera Piloting 1 June 27th 08 08:05 PM
The 6 Things You Could Do to Better Manage Your Aircraft [email protected] Piloting 1 April 24th 07 03:49 PM
Any pilots flown Alisport Silent2 Motor Gliders? Dave Boulter Simulators 0 July 7th 06 11:12 AM
US FAR 61.113 Private Pilots Towing gliders for compensation. Jackal Soaring 21 January 23rd 05 04:37 PM
