Discus 2 Optimal CG location
Old June 24th 18, 08:05 PM posted to rec.aviation.soaring
Dave Springford
Default Discus 2 Optimal CG location
Can anyone advise the optimal CG location for a D2?
If the 2a and 2b have different optimal locations, I would like to know both.
TIA,
Dave
Old June 24th 18, 09:09 PM posted to rec.aviation.soaring
TIA,
Dave
Optimum is where ever you like it best.
I fly mine full aft for the better handling, but it glides better a bit further forward.
Old June 25th 18, 05:17 PM posted to rec.aviation.soaring
Hi Dave,
In normal conditions, I fly mine at station -383 which is what Knauff said was optimal when I bought it in 2002. In strong conditions, where I plan on a lot of high speed cruising, I run at stations -355– -365 to minimize the amount of nosedown trim.
Regards,
Bif “”H7”
Old June 26th 18, 12:01 AM posted to rec.aviation.soaring
Dave Springford
Thanks Bif, That is what I am looking for. My club just bought a 2b and I'm trying to sort out the weight and balance for it.
Old June 26th 18, 02:32 AM posted to rec.aviation.soaring
Michael Opitz
and
Placing a spare battery in the in the tail battery compartment (or
not) seems like something that might work for a club operation.
Lighter pilots fly with no tail battery, while heavier pilots fly with it
installed. (You will have to run the numbers for your specific bird,
as I have no idea what your empty weight is, whether it's had tail
boom repairs, or even if the original owner opted to order it with
a tail battery compartment installed, etc.)
When I first bought my D-2b, that's what Tilo told me to do, and
he suggested that I'd be pretty close to where I wanted to be with
a seat load of ~210#, plus tail battery installed. (I had asked him
to set it up specifically just for me W&B wise before delivery.)
It's a club. There will have to be compromises.
Not numerically detailed like Bif's answer, but it will be hard to nail
down his numbers if there are multiple pilots of different weights
that are going to fly it in a club environment.
RO
Old June 25th 18, 08:42 PM posted to rec.aviation.soaring
TIA,
Dave
Not a long experience. I fly my Discus 2b from about 70 hours.
Not so much but in my opinion it fly better with not much backward load.
I fly mine about half the CG exursion (320-330mm).
One time I try it with more tail load but the glider became unstable and I
need to fly it faster in thermal. I really don't like it.
With a neutral CG in very weak condition I fly it at 42 kg/mq and I thermal it
at about 90-95 km/h without problem.
With avarage/good condition I fly it at about 45 kg/mq and I thermal at 105-110 km/h or more depending on how tight I need to turn.
No experience with more load (short runway).
Old June 25th 18, 09:18 PM posted to rec.aviation.soaring
I fly my 2B about 90% aft empty, but often don't add much tail water when ballasted. Often no tail water, especially in wave. Lead and a brass tail wheel helps with that.
I've found the WB a little unusual though as you need to measure the arms. They are a little different to the manual. I wondered if the wheel is supposed to be jacked somehow during weighing. Does anyone have any ideas about that?
Old June 25th 18, 10:29 PM posted to rec.aviation.soaring
Bruce Hoult
I've found the WB a little unusual though as you need to measure the arms.. They are a little different to the manual. I wondered if the wheel is supposed to be jacked somehow during weighing. Does anyone have any ideas about that?
Are you measuring with the tail on the ground? The glider should definitely be in something resembling flying attitude, though how that is defined for any particular glider is outside the scope of general W&B instructions. The instructions for any particular glider will be in its maintenance manual.
Old June 25th 18, 11:10 PM posted to rec.aviation.soaring
Agreed.
Some ships may be measured with main and tail wheels on the ground, but need a level on the tail boom (with spacers) and THEN measure weights.
Not sure?
Contact those that know, discuss with your local A&P.
Many ways to set up the fuselage, some may measure off structure (spar, wing leading edge, etc.) for data points, some measure "out in space"...,,,,
Read and understand, otherwise, ask a LOT of questions.
Old June 25th 18, 11:35 PM posted to rec.aviation.soaring
Of course it is weighed in the correct SH specified attitude.
Landing out on a corporate mega-farm or other non-traditional ornon-optimal place? son_of_flubber Soaring 25 May 10th 13 12:15 AM
optimal altitude calculations? [email protected] Piloting 18 August 31st 05 03:48 AM
Optimal Frequency of Lessons David B. Cole Aerobatics 18 October 28th 04 12:50 AM
Picking Optimal Altitudes O. Sami Saydjari Instrument Flight Rules 20 January 8th 04 02:59 PM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
