Libelle
Old June 25th 18, 03:40 AM posted to rec.aviation.soaring
Charlie Quebec
Default Libelle
The 201 airfoil is not higher performance than the 301.
Old June 25th 18, 07:13 AM posted to rec.aviation.soaring
Default Libelle
Wikipedia Libelle entry isn't necessarily correct. I read that the 201 had a Wortmann airfoil whereas the article written by Schumann stated that the 301 airfoil was a Heutter airfoil. Maybe the thing is the 201 has the Heutter airfoil that has been mistakenly called a Wortmann in the Wiki entry.
Old June 25th 18, 07:43 AM posted to rec.aviation.soaring
Default Libelle
Maybe mistaken in the Wiki entry and otherwise? Glasfaser must be able to say what the true airfoil section is. From what I'm gathering the 201 and 301 have the same airfoil yet if Wil Schuemann is correct in his assertions the both mentioned Libelle have a Heutter airfoil and not a Wortmann as is seemingly commonly thought.
Old June 25th 18, 08:27 AM posted to rec.aviation.soaring
Default Libelle
If it's any help, I obtained a set of laser cut templates for the Libelle 201b from Streifeneder. They are all marked as FX 66-17AII for all wing stations. The FX series would be a Wortman airfoil.
Mark Guay
Old June 25th 18, 01:14 PM posted to rec.aviation.soaring
Default Libelle
I have built a number of wing wheels and WingRiggers for both the 201 and 301. I can definitely say that the airfoils are very different. The 201 is thicker, with more curvature on the bottom.
Old June 25th 18, 11:29 PM posted to rec.aviation.soaring
Default Libelle
The 301 aerofoil is a lot thinner & designed for flaps so very different.
I have spoken to Christian Streifeneder regarding turbulators, he has pointed out that there may be a case for putting them on the top surface of the wing, but then it would be difficult to wash the wings. He's not convinced they are effective on the underside.
By the way, there is no H in 201 (regardless of what Wikipedia says) - the H in H301 denotes Hutter who was involved in it's design, but the 201 did not.
Cheers,
Nick.
Old June 26th 18, 03:57 AM posted to rec.aviation.soaring
SoaringXCellence
Default Libelle
I just sold my H301 with the Scheumann wing mods. The leading edge is sharper and the entry (stagnation point) is lower. The flaps actuator is modified to let the ailerons move closer to the flaps for cambering.
The Libelle 201 has a much thicker wing and you'll see that if you try to put a H301 canopy on a Libelle 201.
Old June 26th 18, 01:24 PM posted to rec.aviation.soaring
Default Libelle
The airfoils on the Standard Libelle (201) and the H301 Libelle are different. The 201 uses the (Wortmann) FX 66-17AII-182 airfoil, which is 18.2-percent-chord thick. Wil Schuemann brilliantly observed that the 301 airfoil is very similar to an FX 67-K-XXX airfoil except near the leading edge---thus the leading-edge "extension" of the Schuemann modification.
Dan Somers
Port Matilda, Pennsylvania, USA
Libelle 201 canopy [email protected] Soaring 0 July 4th 16 02:03 PM
Club Libelle H 205 POH James Anderson Soaring 1 August 1st 12 07:33 PM
Libelle Wings Steve Leonard Soaring 1 March 1st 07 07:27 PM
Libelle Wings Thermaler Soaring 3 March 1st 07 03:18 PM
Standard Libelle Pam Kurstjens Soaring 4 May 22nd 05 05:40 PM
