The ASH25 incident JJ recounts brings this to mind:
In 2-seater situations where the second pilot is essentially a "ride", is there consideration of the second (if qualified) pilot taking control? Jim |
Broken rudder cable in a Puchacz. Used ailerons to sideslip it all
the way to landing and full airbrakes that reduced rudder effectiveness by about half. Interesting approach and landing across the field. Loose gapseal in LS4 in spiraldive on aileron. Unable to roll out until combination of opposite aileron, rudder and full airbrakes slowly overcame it. |
I believe there is a similar article by Richard Johnson. Remember stick problem - either no forward travel or stick limited to keeping glider in high angle of attack - put glider in turn where that stick configuration is required, buy some time to make a more thought out decision.
Mark |
Training Materials for Pilots Transitioning to Tail Dragger Gliders? | Papa3[_2_] | Soaring | 0 | July 7th 13 02:03 PM |
Pilots in India often fail alcohol tests | Larry Dighera | Piloting | 1 | June 27th 08 08:05 PM |
The 6 Things You Could Do to Better Manage Your Aircraft | [email protected] | Piloting | 1 | April 24th 07 03:49 PM |
Any pilots flown Alisport Silent2 Motor Gliders? | Dave Boulter | Simulators | 0 | July 7th 06 11:12 AM |
US FAR 61.113 Private Pilots Towing gliders for compensation. | Jackal | Soaring | 21 | January 23rd 05 04:37 PM |
