Libelle
Old June 25th 18, 11:29 PM posted to rec.aviation.soaring
Default Libelle
The 301 aerofoil is a lot thinner & designed for flaps so very different.
I have spoken to Christian Streifeneder regarding turbulators, he has pointed out that there may be a case for putting them on the top surface of the wing, but then it would be difficult to wash the wings. He's not convinced they are effective on the underside.
By the way, there is no H in 201 (regardless of what Wikipedia says) - the H in H301 denotes Hutter who was involved in it's design, but the 201 did not.
Cheers,
Nick.
Old June 26th 18, 03:57 AM posted to rec.aviation.soaring
SoaringXCellence
Default Libelle
I just sold my H301 with the Scheumann wing mods. The leading edge is sharper and the entry (stagnation point) is lower. The flaps actuator is modified to let the ailerons move closer to the flaps for cambering.
The Libelle 201 has a much thicker wing and you'll see that if you try to put a H301 canopy on a Libelle 201.
Old June 26th 18, 01:24 PM posted to rec.aviation.soaring
Default Libelle
The airfoils on the Standard Libelle (201) and the H301 Libelle are different. The 201 uses the (Wortmann) FX 66-17AII-182 airfoil, which is 18.2-percent-chord thick. Wil Schuemann brilliantly observed that the 301 airfoil is very similar to an FX 67-K-XXX airfoil except near the leading edge---thus the leading-edge "extension" of the Schuemann modification.
Dan Somers
Port Matilda, Pennsylvania, USA
Old July 16th 18, 08:39 PM posted to rec.aviation.soaring
Default Libelle
This clarifies the airfoil matter for me thanks.
Old July 29th 18, 03:13 AM posted to rec.aviation.soaring
Default Libelle
I'm looking at going ahead with purchasing a 201 project. It was damaged and needs to be thoroughly checked out with minimum repairs being fiberglass to the leading edge of one wing that had contacted a fence post or small tree on an off field landing and a new canopy. I'd like to find a person who may be able to transport the glider for me to California from Pennsylvania. I can't afford to pay a lot. Maybe someone knows someone who happens to be road tripping out to California from the East Coast?
Libelle 201 canopy [email protected] Soaring 0 July 4th 16 02:03 PM
Club Libelle H 205 POH James Anderson Soaring 1 August 1st 12 07:33 PM
Libelle Wings Steve Leonard Soaring 1 March 1st 07 07:27 PM
Libelle Wings Thermaler Soaring 3 March 1st 07 03:18 PM
Standard Libelle Pam Kurstjens Soaring 4 May 22nd 05 05:40 PM
