Discus 2 Optimal CG location
Old June 26th 18, 08:19 PM posted to rec.aviation.soaring
Default Discus 2 Optimal CG location
Hi Dave,
good practice is to trim a standard class glider at a speed of 120-130kph with elevator in neutral position without water ballast. This keeps elevator deflection low in the relevant speed ranges. It usually results in a mid-range to slightly aft C/G position at your take-off weight.
Such a setup can easily be achieved with a few test flights and the help of a folding rule, adding ballast as required. You will need to stay within allowed C/G ranges, of course.
I'm flying an LS8, but what I heard from Discus 2 pilots at various competitions is in line with what RO said. The D2 has a reputation of rather poor handling with aft C/G locations.
Best regards,
Christoph
Old June 27th 18, 03:55 AM posted to rec.aviation.soaring
Dave Springford
Thanks Michael and Christoph,
Good information.
Landing out on a corporate mega-farm or other non-traditional ornon-optimal place? son_of_flubber Soaring 25 May 10th 13 12:15 AM
optimal altitude calculations? [email protected] Piloting 18 August 31st 05 03:48 AM
Optimal Frequency of Lessons David B. Cole Aerobatics 18 October 28th 04 12:50 AM
Picking Optimal Altitudes O. Sami Saydjari Instrument Flight Rules 20 January 8th 04 02:59 PM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
