Emergency Exit
Old June 30th 18, 07:34 PM posted to rec.aviation.soaring
Dave Walsh
Default Emergency Exit
At 14:33 30 June 2018, Dan Marotta wrote:
To me the major advantages of a BRS over a personal
parachute are the
speed and certainty of deployment.Â* Of course either
system may fail or
malfunction, but with the BRS, you lose the difficulty of
getting out
into space and deploying at in unfavorable position. Simply
pull the
handle and enjoy the ride.
But, upon landing in a windy situation, you run the very
real risk of
being killed in a tumbling, disintegrating wreck being
dragged along the
ground.Â* Is there a jettison capability that could be armed
by the
sudden deceleration of landing?Â* Perhaps an automatic
jettison?Â* Might
that malfunction at 500' and give you a last thrilling ride?
On 6/29/2018 10:49 PM, Charlie Quebec wrote:
Beacause floating around out of control under a
parachute is safer?
BRS sounds good, but in practice I would prefer a
personal chute every
time.
Dan, 5J
Of course you could be struck by lightening as you descend
under your BRS canopy but has anyone ever died being
"dragged along the ground" after a successful BRS escape?
Plenty have died following a conventional parachute mal-
function.
The bottom line is that BRS will work at a lower height but is
hardly available in any common sailplane on sale today.
Retro fitting a BRS to an EASA sailplane would be a
expensive, possibly impossible, task. With ultra-light
sailplanes it's different.
The other major problem, as clearly explained on DG's
website, is that "safety does not sell sailplanes". The
majority of DG sailplanes sold were NOT equipped with the
NOAH system: the new buyers simply did not order the
NOAH system. Even if BRS was available today how many
buyers would buy it?
Dave W
Old June 30th 18, 08:04 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
parachute are the
system may fail or
getting out
pull the
real risk of
dragged along the
by the
jettison?Â* Might
parachute is safer?
time.
Dan, 5J
function.
Dave W
If a BRS system were available factory installed at a reasonable price, I suspect that a very large percentage of buyers would sign up. It's a huge selling point if you are trying to get the OK from your spouse to upgrade to a new glider.
Offering a BRS system standard on all of their airplanes is probably the #1 reason that Cirrus is now the largest piston engine aircraft manufacturer in the world.
Old July 1st 18, 09:59 PM posted to rec.aviation.soaring
Dave Walsh
personal=20
parachute are the=20
speed and certainty of deployment.=C2=A0 Of course
either=20
system may fail or=20
of=20
getting out=20
Simply=20
pull the=20
very=20
real risk of=20
being=20
dragged along the=20
ground.=C2=A0 Is there a jettison capability that could
be armed=20
by the=20
sudden deceleration of landing?=C2=A0 Perhaps an
automatic=20
jettison?=C2=A0 Might=20
ride?
Beacause floating around out of control under a=20
parachute is safer?
a=20
time.
--=20
Dan, 5J
descend=20
being=20
escape?
function.
but is=20
Retro fitting a BRS to an EASA sailplane would be a=20
expensive, possibly impossible, task. With ultra-light=20
DG's=20
website, is that "safety does not sell sailplanes". The=20
the=20
the=20
many=20
Dave W
reasonable price, I
s=
up. It's a huge
s=
spouse to upgrade
to=
a new glider. =20
probably the
#1=
manufacturer
in the world.
Yes you're probably quite right about the Cirrus BUT in a
Cirrus you might well have wife and kids along for the ride.
The fact remains that the majority of DG customers do not
specify the NOAH system; it's actually relatively cheap
compared to the new cost of a DG808C or DG1000x. Why is
that?
Dave W
Old July 2nd 18, 05:41 PM posted to rec.aviation.soaring
I had the opportunity to fly with a Ventus 2BXR (R for Recovery) at Saint-Auban (France). With that experience, I'd say a BRS in a glider is not a very practical solution as far as I'm concerned.
Due to the ballistic extractor being placed under the fuselage skin between the wings, it could shoot out exactly where your head would be when pushing the glider. Therefore, there are multiple safety systems to verify, a separate electrical circuit, a safety pin to extract just before taking off, and to put back in place after landing before exiting the glider. Sure as hell, you are bound to forget something if you do not strictly follow a written checklist every time.
At Saint-Auban, I had to sign a specific document stating my knowledge of the system before being allowed to fly the glider. The CNVV ended up selling the glider because these limitations made it financially uninteresting.
I once forgot to take the safety pin out (you still can do it in flight, fortunately), once to put it back (really a bad idea, but I'm not used to a check-list before exiting a glider)...
Stephane
Le samedi 30 juin 2018 21:04:53 UTC+2, Mike Schumann a écritÂ*:
parachute are the
system may fail or
getting out
pull the
real risk of
dragged along the
by the
jettison?Â* Might
parachute is safer?
time.
Dan, 5J
function.
Dave W
Old June 30th 18, 06:01 AM posted to rec.aviation.soaring
Tango Whisky
Schempp-Hirth does offer a BRS for the Ventus.
Old June 30th 18, 01:51 PM posted to rec.aviation.soaring
Dave Walsh
I have seen no data for the reliability of ballistic recovery
systems in sailplanes (or, indeed, in ULM/Microlights) but the
German data for survivability of conventional parachute bail-
outs from gliders makes very sobering reading.
I'd be very surprised if ballistic recovery chutes didn't turn out
to have a better record than conventional parachutes.
A majority of ULM/Microlights here in France have ballistic
recovery systems; you don't here of malfunctions very often,
but again I have no data.
I know three glider pilots who have had mid-airs, all three
bailed out, only one is still alive.
Dave W
Air exit vent with engine box? [email protected] Soaring 5 December 8th 15 04:14 AM
An elegant exit Frank Whiteley Soaring 2 May 15th 09 02:28 PM
Accident report - PDA's can restrict emergency exit Ramy Soaring 21 December 31st 06 05:45 PM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
