Air exit vent with engine box?
Old December 6th 15, 01:02 AM posted to rec.aviation.soaring
Default Air exit vent with engine box?
On Thursday, November 19, 2015 at 10:01:49 PM UTC-5, Jonathan St. Cloud wrote:
Was wondering if anyone has figured out a good air exit vent for a glider with an engine box i.e., ASG-29E, ASW-28E, ASW-24E, Nimbus 4T...
The producers of the ES Vent, which is commonly installed in 24's, 27's, 28's, and 29's, as well as a hand full of other types, have looked at the issue of installing a vent using the design principles that work well in the above in the 29E and similar gliders. All of the Schleicher motorized gliders that have fuel tanks in the baggage compartment share 2 issues.
1. The aft bulkhead in the baggage compartment is a bit too far forward to allow placement where experience with the other similar types shows it should be. This would require a very special vent that would have to have alteration to the bulkhead. This is something we do not think is wise as it is important structure. Even if we could engineer this, and get approved by the factory, the installation would be very complex.
2. To create a collector to lead into the vent smoothly would require alterations to the fuel tank. We aren't going to do that for reasons described above.
As of this time we do not yet have a practical solution for these gliders.
UH
Old December 6th 15, 06:53 PM posted to rec.aviation.soaring
Jonathan St. Cloud
What are the draw backs of using the DG Mandel type air exit as this seems more viable than the ES style vent?
As of this time we do not yet have a practical solution for these gliders..
UH
Old December 6th 15, 07:29 PM posted to rec.aviation.soaring
Is it worthwhile fitting a vent unless the particular vent design and location are proven to be effective for your glider type? There is a little article on the JS website about the design of their one.
http://www.jonkersailplanes.co.za/airextractor.htm
Old December 6th 15, 10:47 PM posted to rec.aviation.soaring
It very much depends on whether there is a low pressure area on the fuselage that will provide the suction needed to be effective. If there is, the next issue is whether it is in a place where the structure will permit installation as well as being able to provide and install the inner portions of the system that bring the airflow smoothly up to free stream speed.
I repaired 2 holes in a Discus 2 resulting from 2 failed attempts.
UH
Old December 7th 15, 06:51 AM posted to rec.aviation.soaring
JS
Flew with a high-tech mod today:
A (dry) sponge from my washing kit jammed into the collector of the Uncle Hank exhaust in the 29.
At one point wanted some ventilation. (Never did get to the freezing level.)
Discovered that the air vents don't work very well with the exhaust plugged.
Old December 8th 15, 05:14 AM posted to rec.aviation.soaring
But it was so quiet, you didn't notice the wheel was still downt. ;-)
Air exit vent with engine box? Tango Whisky Soaring 14 November 25th 15 08:06 PM
Apollo 11 Astronauts exit CM - LIFE.jpg J3 Aviation Photos 0 July 21st 09 04:13 AM
An elegant exit Frank Whiteley Soaring 2 May 15th 09 03:28 PM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 03:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 09:01 PM
