Flarm with IGlide?
Old July 1st 18, 05:30 PM posted to rec.aviation.soaring
Default Flarm with IGlide?
It’s possible with airconnect from Airvionics
Old July 1st 18, 09:39 PM posted to rec.aviation.soaring
Thanks, that looks like it will work. Does all of the flarm into show up on the IGlide map? Do you know of any manuals or literature that explain how it works?
Old July 2nd 18, 01:53 AM posted to rec.aviation.soaring
jfitch
That's the only thing that will work. Sadly, the iGlide documentation is out of date. What you should see is all Flarm targets except PCAS (I don't think it knows what to do about them and really neither do you). These will be depicted on the screen at any zoom level as a little glider or airplane, depending on what it is, along with altitude and climb rate. You can touch them and get any other information, once selected you can set it as the one referred to in the Nav boxes (if you have any set up for Flarm); also you can label it with a color and it will always appear in that color. It's tracks will be shown if you have that turned on, and in that color.
When there is a warning, you will get an audible warning from the iOS device which will probably not be that loud. You will also get a red triangle emanating from the center of the display toward the edge indicating where to look for the threat. The triangle is quite obvious if you are looking anywhere near the device.
Some of these features may require the higher levels of iGlide, not sure about that. And all of that is from the data going through the Air Vario rather than the Air Connect, though it should be the same - same source and data.
Old July 2nd 18, 03:17 AM posted to rec.aviation.soaring
Charlie Quebec
I wouldn’t rely on any one display, in my glider I have a small butterfly FLARM display, an Android XCsoar and a DVS voice module.
Old July 3rd 18, 12:13 AM posted to rec.aviation.soaring
I’m going to go with the Flarm LED display and also air connect to the iPad. We’ll see how it works soon!
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
