AS 33
Old July 5th 18, 02:07 AM posted to rec.aviation.soaring
Charlie Quebec
Default AS 33
If the JS3 had quality control it might. Ive seen 4 new ones with faults from factory so far.
I wouldnt touch anything Jonkers after seeing the defects.
Old July 5th 18, 03:34 AM posted to rec.aviation.soaring
Waveguru
Default AS 33
What were the defects?
Boggs
Old July 5th 18, 04:30 AM posted to rec.aviation.soaring
Default AS 33
Please do tell; what registry and ID would they be? And after identifying, please share exactly what defects disturbed you?
Old July 5th 18, 05:34 AM posted to rec.aviation.soaring
Charlie Quebec
Default AS 33
3 x faulty tail wheel cable swaging.
1x engine hinge hole drilled thru radio coax, and leaking water from outer panel rear drag pin.
All brand new from factory.
Old July 5th 18, 05:42 AM posted to rec.aviation.soaring
Charlie Quebec
Default AS 33
3 cases with badly staged tail wheel retract cable, one with engine bay cover hinge hole drilled thru radio coax and water leak from outer panel rear drag pin.
No, you won’t be getting any rego info, I saw them personally in the repair shop.
Old July 5th 18, 05:51 AM posted to rec.aviation.soaring
Charlie Quebec
Default AS 33
That’s all the info you need, in deference to the repairer, that’s all your getting.
All seen by in person.
Old July 5th 18, 08:45 PM posted to rec.aviation.soaring
Paul T[_4_]
Default AS 33
At 04:51 05 July 2018, Charlie Quebec wrote:
3 x faulty tail wheel cable swaging.=20
outer
panel rear drag pin.=20
All brand new from factory.=20
That=E2=80=99s all the info you need, in deference to the repairer,
that=E2=
=80=99s all your getting.
and S/H DG. ASW etc have had no quality control issues in the past? Come
on.
Old July 6th 18, 12:52 AM posted to rec.aviation.soaring
Charlie Quebec
Default AS 33
Ive never seen any of those brands in the same repair shop with faults from new.
Perhaps instead of hand waving you could show some examples?
Yeh, I thought not.
Old July 6th 18, 12:57 AM posted to rec.aviation.soaring
Ben Coleman
Default AS 33
To be fair, all the discus family with spar bonding issues iirc.
Cheers Ben
Old July 6th 18, 02:16 AM posted to rec.aviation.soaring
[email protected][_1_]
Default AS 33
Where to start?
AS-W20 wing angle of incidence wrong on many brand new ships. Many -20's required new control surfaces.
Numerous modern ships of all flavors with significant "spar waves". Same with gel coat that was failing from when shipped. If gliders were pickups, there would be class action lawsuits over these issues.
Recent bolt issues in Wankel engines.
Numerous examples of all brands where the as-built ship does not match the blueprints in either the composite structure or the hardware install.
Not that i could ever afford it, but I would never buy a brand new ship. All are one-off handbuilt with lots of opportunity for operator error.
