AS 33
Old July 6th 18, 01:25 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by Charlie Quebec View Post
Ive never seen any of those brands in the same repair shop with faults from new.
Perhaps instead of hand waving you could show some examples?
Yeh, I thought not.
A snippet from a SH TN for example
SUBJECT: Elevator, fixing of mass balance weights
AFFECTED: Sailplane Ventus-2a, Ventus-2b (TC-No.: 349)
(all S/Nos complying with Modification Bulletin No. 349-42 or modified
according Technical Note No. 349-27 and equipped with a new tail unit))
S/Nos: 1, 2, 31, 32, 48, 54, 71, 117, 124 through 151 and 153
Sailplane Discus-2a, Discus-2b (TC-No.: 360)
S/Nos: 1 through 185, 187 through 189
Powered sailplane Discus-2T (TC-No. 863)
S/Nos: 1 through 33
REASON: During a pre-flight check of a Discus-2T a roughness of the elevator
control was noticed. After the removal of one elevator two loose
pieces of lead were found. The outmost mass balance weight was
separated and broken in two pieces.
Old July 6th 18, 05:32 PM posted to rec.aviation.soaring
Default AS 33
Yeh, I thought not.
On delivery. Gliders I have bought new:
LS7: OK
Discus Bt OK - but it was completed and fitted out in the UK.
Duo T - TE tube not connected in the fin.
Discus 2cT - a tailplane rigging knob found to be stuck between the base of the fin and rudder (presumably dropped down form the top in the factor.
JS1c - fin ballast dump valve blocked. I spent 2 full days at the factory inspecting, test flying and collecting that one and we all still missed it.
Like someone else said, they are all hand built. They go through different fittings installations depending on the owner's requirements. I'd happily buy from JS, SH or Schleicher and am waiting for a Ventus at present.
Old July 6th 18, 05:39 PM posted to rec.aviation.soaring
Default AS 33
JS-1C............’Da Bomb!!!!
Old July 5th 18, 08:51 PM posted to rec.aviation.soaring
Paul T[_4_]
Default AS 33
At 04:51 05 July 2018, Charlie Quebec wrote:
3 x faulty tail wheel cable swaging.=20
1x engine hinge hole drilled thru radio coax, and leaking water from
outer
panel rear drag pin.=20
All brand new from factory.=20
That=E2=80=99s all the info you need, in deference to the repairer,
that=E2=
=80=99s all your getting.
All seen by in person.
First V3a - undercarriage collapse today at the worlds see Adam Woolleys
FB page.
Old July 5th 18, 09:52 PM posted to rec.aviation.soaring
Ron Gleason
Default AS 33
outer
that=E2=
FB page.
Adam just popped a tube today, all is good with him and the plane. One more practice day before the real circus begins
Old July 5th 18, 10:05 PM posted to rec.aviation.soaring
Paul T[_4_]
Default AS 33
outer
that=E2=
Woolleys
FB page.
Apologies read his post wrong.
Old July 6th 18, 10:04 AM posted to rec.aviation.soaring
Justin Craig[_3_]
Default AS 33
Not a collapse,
Punctured tyre.
FB page.
