Top Hat Question (XCSoar?)
Old July 9th 18, 06:22 PM posted to rec.aviation.soaring
Default Top Hat Question (XCSoar?)
Just to close the loop on this Top Hat question, it does not appear that I can do what I want to do. I flew both days this past weekend and tried different configurations. Top Hat will autoswitch from cruise screen to circling screen and back again. It will autozoom when circling so the pilot can see the zoomed-in overhead view of the track within a thermal. And it will allow one-click switching from zoomed-in thermaling view (including whatever infoboxes are configured for the circling screen) to zoomed-out cruise view (with the cruising infoboxes).
But it will not automatically switch from cruise screen (zoomed out) to circling screen (autozoomed in) and allow one-click switching back to the cruise view to get a quick pick at nearby landing sites, other gliders (with FLARM input), and surrounding terrain and airspace.
I compromised on one-click manual switching from cruise to climb. It's better for me than the autozoom into thermaling view because I can switch to zoomed out view with only one click on the Screens button. But the manual switching each time I want the circling view is annoying because all the logic is there to autoswitch and zoom; I just can't control them to get the effect I want.
Thanks for the input! I'm not sure there's a lot of development work being done on Top Hat at the moment but I'll submit this as a request.
Chip Bearden
Old July 9th 18, 10:08 PM posted to rec.aviation.soaring
Chip Bearden
Thanks Chip. I second your request. Specifically: after I manually switch from (auto-entered) circling screen to cruise screen I want to be able to manually go back to the circling screen. Robert Dunning has made other changes to Tophat by request before, hopefully he'll do it again. And Thank You Robert for this nice software!
Old July 9th 18, 11:05 PM posted to rec.aviation.soaring
I agree, Rob Dunning has been great, helping push through a number of changes I asked about in the two years since I started using Top Hat. I wasn't sure this latest one required a software change; I thought I might just not have configured it properly, that everyone else was already flying around with this feature.
But it appears not (please show me I'm wrong!!!). From my perspective, the change isn't significant: i.e., just autoswitch between cruise and climb--as occurs now--while retaining the user's most recent zoom levels for each screen--which doesn't appear to occur now (the same zoom level is used for both screens). I had thought the Distinct Zoom feature--which presumably changed zoom to a screen-level rather than a global parameter--took care of this but that appears to be true only for manually switched screens, not autoswitching.
Chip Bearden
Old July 9th 18, 11:30 PM posted to rec.aviation.soaring
Chip Bearden
And, I should add, in addition to autoswitching, allow manual switching from climb to cruise or vice versa at any time, while retaining the same pre-existing zoom levels for each screen.
Chip Bearden
Old July 10th 18, 02:31 AM posted to rec.aviation.soaring
Yes I agree. I with your request Chip. I have a second question. Is there a way to fix the screen on cruise? If there is I cant find it. The only choice I can find is setting "auto zoom" to "manual" which I assume still automatically switches to circling.
Old July 10th 18, 02:59 AM posted to rec.aviation.soaring
Wyll Surf Air
If you go to look pages
And in the infobox section select cruise (rathere then auto) then it will lock it in cruise
Old July 11th 18, 12:34 AM posted to rec.aviation.soaring
Thank you. That was a big help. I actually have two screens running and want to fix one on cruise.
Old July 11th 18, 03:26 PM posted to rec.aviation.soaring
Soartech
Is there really a menu item called LOOK? I have never seen it in either program. Where is it?
XCSoar Question Dan Marotta Soaring 9 June 16th 16 02:58 PM
CAI-302 and XCSoar Dan Marotta Soaring 7 March 29th 12 09:55 PM
XCsoar 6.2.6 Question Karl Kunz Soaring 8 March 16th 12 04:12 PM
xcsoar [email protected] Soaring 40 August 13th 09 09:01 PM
XCSoar jorgie Soaring 2 November 2nd 04 12:05 AM
