Decades ago, I did a "first flight of the season" in a ASW-20. Normal preflight of, "cup hand around tail probe and blow" yielded sorta normal needle movement.
At about 200', airspeed was low (glider felt solid), so continued flight. Flew for a couple hours, landed fine, derigged. Found a rodent had chewed through a pressure tube. A quick blow looked fine, steady state had a leak. I had reverted to, "does it look good, does it feel good, does it sound good?". Decent short cross country, woulda sucked for a competition. So, unless IFR, revert to basics, hopefully you were taught the basics...... IFR stresses, "believe the instruments, verify what is correct". |
Training Materials for Pilots Transitioning to Tail Dragger Gliders? | Papa3[_2_] | Soaring | 0 | July 7th 13 02:03 PM |
Pilots in India often fail alcohol tests | Larry Dighera | Piloting | 1 | June 27th 08 08:05 PM |
The 6 Things You Could Do to Better Manage Your Aircraft | [email protected] | Piloting | 1 | April 24th 07 03:49 PM |
Any pilots flown Alisport Silent2 Motor Gliders? | Dave Boulter | Simulators | 0 | July 7th 06 11:12 AM |
US FAR 61.113 Private Pilots Towing gliders for compensation. | Jackal | Soaring | 21 | January 23rd 05 04:37 PM |
