Cobra Trailer Bearings
Old July 11th 18, 08:25 PM posted to rec.aviation.soaring
Default Cobra Trailer Bearings
Great.
Be mindful of axle nut torque values. Too tight or too loose can waste a bearing very quickly. A spec sheet with the bearing, or online, can show the correct torque value.
Banging it on with an impact wrench is not correct.
Old July 11th 18, 08:44 PM posted to rec.aviation.soaring
JS[_5_]
Below from the Cobra manual, p9:
https://www.cobratrailer.com/wp-cont...ns_30-4-14.pdf
5.3.4 ALKO EURO Axles are equipped with maintanance free compact bearings
If necessary, adjust the axial play of the wheel bearing
- Remove the decoration and the wheel-hub cap.
- Remove the split-pin from the castellated wheel nut.
- Tighten the nut while spinning the wheel until a resistance is felt. If possible use a torque wrench
(50 Nm).
- Turn the castellated nut 1/12 of a turn (30°, see diagram 1) then turn back to the next pin
alignment position.
Axial play to 0.05 mm is acceptable.
Overtightening will cause bearing damage
- Check grease for quantity and condition, top-off or renew, if necessary
- Grease type for wheel bearings: Multi-purpose grease DIN 51825 KTA3K
- Replace wheel hub caps
Cobra wheel bearings Wade G Soaring 3 February 20th 17 02:16 PM
PIK 20 Trailer Bearings [email protected] Soaring 1 May 27th 16 09:58 PM
Sealed Cobra wheel bearings [email protected] Soaring 1 July 13th 15 05:23 AM
cobra wheel bearings and brakes [email protected] Soaring 4 August 13th 12 11:21 PM
