On Monday, July 9, 2018 at 8:51:27 PM UTC-4, wrote:
I screwed up big time and burned the bearings on both wheels by leaving the brake on (I know, I'm getting forgetful). Wings and Wheels is out of the ALCO 1637 bearing sets and will not get any until mid August. Does anyone have two of these bearing sets? I need them early next week so that I can go to Mackay,ID for some of the best soaring ever. If anyone can help me out, please contact me at . Stu Larimore 2Z 208-724-0587 A bit of a warning from experience(of others I've observed or helped). If things got hot enough to wreck the bearings you need to be concerned about the drums. They can become very brittle when they get overheated. Any discoloration is a clue. Also, if the spindles show discoloration they need to be replaced. UH |
Echoing UH's warning, the drum can crack in the thick area where the bearings are inserted. Don't know what caused the one we found but I suspect heating it up to higher than normal temps doesn't help. Eventually the grease all leaked out and the bearings died...a half day's drive from home, of course...on a Sunday.
BTW, I've had more difficulty getting the grease seals for older trailers than the bearings. Chip Bearden |
Cobra wheel bearings | Wade G | Soaring | 3 | February 20th 17 02:16 PM |
PIK 20 Trailer Bearings | [email protected] | Soaring | 1 | May 27th 16 09:58 PM |
Sealed Cobra wheel bearings | [email protected] | Soaring | 1 | July 13th 15 05:23 AM |
cobra wheel bearings and brakes | [email protected] | Soaring | 4 | August 13th 12 11:21 PM |
