Cobra Trailer Bearings
Old July 12th 18, 02:42 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Default Cobra Trailer Bearings
On Monday, July 9, 2018 at 8:51:27 PM UTC-4, wrote:
I screwed up big time and burned the bearings on both wheels by leaving the brake on (I know, I'm getting forgetful). Wings and Wheels is out of the ALCO 1637 bearing sets and will not get any until mid August. Does anyone have two of these bearing sets? I need them early next week so that I can go to Mackay,ID for some of the best soaring ever.
If anyone can help me out, please contact me at .
Stu Larimore
2Z
208-724-0587
A word of warning----Experience from a 2000 Cobra with a new '27B in it, and a Cobra with a DG800B in it. The 4 Bolt hub for the '27, and the 5 Bolt hub for the DG have different size bearings. They are sealed, double row bearings, used in front wheel drive small car front wheels. They must be pressed out with an "industrial" grade press.
The instructions as posted by JS are totally wrong (I have a different Cobra manual) and are not applicable to these straight cylindrical bearings. The instructions apply to the classic tapered roller bearings as found on most trailers. For these straight cylindrical bearings, a flange nut is used and tightened to 225 ftlb of torque. Loctite is recommended. A half-inch drive socket, Breaker bar, and 4 ft cheater is needed to remove the nut, especially if Loctite has been used.
The bearing size is laser engraved on the bearing and a NAPA or good auto machine shop can cross reference.
I keep a spare set of bearings in my trailer, and one drum with new bearing also.
Old July 12th 18, 06:11 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
This is half comment and half question.
I wanted to pick up some brake shoes for my Cobra trailer (circa 2002) for the AL-KO axle assembly. I crawled underneath to look at the back side of the backing plate and found "Typ 2051" (pictures at http://aviation.derosaweb.net/asw27/documents/Trailer). This 2051 number seems to align with these Taunton brake parts (https://www.tauntontrailers.co.uk/af...set-1406-p.asp.
So now to my question: Can I, should I, assume that the "Typ 2051" also applies to the correct bearings needed for this axle?
Thanks, John OHM Ω
Cobra wheel bearings Wade G Soaring 3 February 20th 17 02:16 PM
PIK 20 Trailer Bearings [email protected] Soaring 1 May 27th 16 09:58 PM
Sealed Cobra wheel bearings [email protected] Soaring 1 July 13th 15 05:23 AM
cobra wheel bearings and brakes [email protected] Soaring 4 August 13th 12 11:21 PM
