Cobra trailer aluminum vs fiberglass top
Old July 15th 18, 03:08 AM posted to rec.aviation.soaring
Default Cobra trailer aluminum vs fiberglass top
I've never been able to find an aluminum trailer with the factory insulation package. Can anyone direct us to pictures and insulation specifics? My concern is it would be "delicate" and have a tendency to "pick".
If you were going to add insulate to an older trailer, what specific product would you use?
Old July 15th 18, 05:32 PM posted to rec.aviation.soaring
I looked at one several years ago and the insulation on that one appeared to be black "rubbery" expanded foam - not polystyrene foam. I have the same decision to make and will ask Spindelberger to send a sample.
Old July 16th 18, 04:49 PM posted to rec.aviation.soaring
bumper[_4_]
There are a number of self adhesive foam insulations available that are reasonably priced. I've also used the reflective "bubble wrap" stuff with 3M 77 or 90 spray adhesive (though that isn't so suitable for trailers). It doesn't need a high R value as it only needs to prevent condensate on interior surfaces. This stuff on Amazon looks interesting:
https://www.amazon.com/Noico-waterpr...oam+insulation
bumper
Old July 16th 18, 08:07 PM posted to rec.aviation.soaring
bumper
1/16" of an inch seems awful thin. Wonder what is the thickness of the Spindelberger insulation?
Old July 16th 18, 08:30 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Mon, 16 Jul 2018 12:07:43 -0700, bensoaring wrote:
https://www.amazon.com/Noico-waterpr...Self-adhesive-
Deadening/dp/B07CZ2DHV3/ref=sr_1_20?
ie=UTF8&qid=1531726529&sr=8-20&keywords=self+adhesive+foam+insulation
The web page says 1/6" (4mm) thick.
A clubmate had good anti-condensation results from lining a trailer with
3mm (1/8") polystyrene wallpaper underlay held on with contact cement, so
this stuff, which looks to be a lot more resistant to water penetration
as well as 33% thicker and denser than the polystyrene should be better.
Martin | martin at
Gregorie | gregorie dot org
Painting fiberglass Cobra trailer [email protected] Soaring 12 January 19th 13 02:23 AM
Aluminum top Cobra trailer leaks - how frequent? AK Soaring 9 March 30th 10 12:44 AM
Fiberglass adhesion to aluminum? [email protected] Home Built 19 January 7th 06 03:58 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
