Home built trailer for old glass ship
Old July 19th 18, 03:14 AM posted to rec.aviation.soaring
Default Home built trailer for old glass ship
Having built over 40 enclosed trailers based on the Schreder/Minden Fabrication design concept, I can offer some insight. The Phoebus has a very large wing, with a thick airfoil and very wide chord at the root. Combined with the rather wide and tall fuselage, the trailer profile must be large enough to comfortably house these primary components without undue interference. I seriously doubt that just purchasing some unknown "trailer" (especially an "enclosed" model) will be satisfactory.
Make a cardboard template of the fuselage profile as viewed from the front.(Including any wing root fairings and protruding pins.) Make two templates of the wing root profile. Stack them together and try to draw an arch (or rectangle) around them, leaving at least a couple of inches clearance between the trailer profile and the wings, as well as the wing to fuselage. You will be shocked at the actual dimensions necessary to fit a Phoebus, Any trailer you purchase, build or otherwise acquire MUST meet the minimum profile dimensions, or you will waste a lot of time and money getting something that simply WILL NOT WORK!
And don't forget the vertical dimension of the rudder. It is pretty tall on the Phoebus, and if the "doghouse" rudder enclosure isn't tall enough, you have another problem.
Yes, I could build a trailer for the Phoebus. No, I am not willing to do so for less than $18,000. And probably not then anyway. I am getting too old for this.
Old July 19th 18, 05:18 AM posted to rec.aviation.soaring
John Foster
On Wednesday, July 18, 2018 at 8:14:29 PM UTC-6, wrote:
Having built over 40 enclosed trailers based on the Schreder/Minden Fabrication design concept, I can offer some insight. The Phoebus has a very large wing, with a thick airfoil and very wide chord at the root. Combined with the rather wide and tall fuselage, the trailer profile must be large enough to comfortably house these primary components without undue interference.. I seriously doubt that just purchasing some unknown "trailer" (especially an "enclosed" model) will be satisfactory.
Thanks. This sounds like a good idea. My initial thought was to find a flatbed trailer that was long enough (24 ft?) and build something on top of that. I'm comfortable with fiberglass. My welding is below novice level, but can learn. Barring that, I would need to find an axil and trailer hitch and build a custom trailer off that. I'm comfortable building and designing things, and for a one-time or winter project I think it could be fun. But I do see the sense in buying something that is functional and pre-made to save some time and money, if you can find something that will fit/work.
Old July 19th 18, 08:57 AM posted to rec.aviation.soaring
Charlie Quebec
You are more likely to find an old trailer for a 2 seater, such as a IS28, Blanik, or Twin Astir suitable.
Starting out with an open flatbed and adding a top later could work too.
All of those would take a Pheobeus.
Old July 19th 18, 12:17 PM posted to rec.aviation.soaring
We have a nice trailer for a Blanik L-13. It has slings that roll the wings in and out so, should work for any type of glider. See wings and wheels under trailers. Make us an offer.
Tim Hanke
Adirondack Soaring
Saratoga Springs, NY
518-693-6849
Old July 19th 18, 03:28 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
So, Mark, the question then becomes, "Would you be willing to build hoops for a trailer?" :-) Yep, building a large number of hoops to the same shape is no small task!
Steve Leonard
Tying down a fiber glass ship. [email protected] Soaring 31 January 29th 18 01:44 PM
The Glass Ship Frank Whiteley Soaring 1 January 24th 17 01:45 PM
Paperwork list for experimental glass ship John[_27_] Soaring 3 March 7th 10 04:13 PM
Buying a used home-built? Jay Honeck Owning 27 January 16th 05 08:15 PM
Engine for home built Chris Gumm Piloting 2 September 16th 04 12:52 AM
