On Tuesday, July 24, 2018 at 9:29:03 PM UTC+2, Blue Whale wrote:
OK, I'm an idiot, don't "PowerFLARM units also include an IGC approved GPS flight recorder?" Good question! Yes, it certainly does. "This option will enable you to prove records up to and including diamond badges in accordance with FAI Sporting Code. The option adds a strong cryptographic signature to IGC files as well as enables task declarations. The pressure sensor is uncalibrated, since calibration isn’t necessary for most flights." The IGC file format does allow for airspeed info, of course, but PowerFLARM does not record Airspeed records in its IGC files, which are limited up to the three diamond badges. |
Fatal this afternoon | Gene Seibel | Piloting | 6 | March 7th 07 09:22 PM |
1 Fatal ...r.a.h or r.a.p? | Montblack | Piloting | 81 | February 12th 06 08:54 AM |
1 Fatal ...r.a.h or r.a.p? | Montblack | Home Built | 99 | February 12th 06 08:54 AM |
1 Fatal ...r.a.h or r.a.p? | Montblack | Piloting | 38 | February 9th 06 02:00 PM |
Fatal at Omarama | Philip Plane | Soaring | 0 | January 12th 05 07:52 PM |
