On 07/25/2018 08:44 PM, kinsell wrote:
On 07/24/2018 08:16 PM, Craig Funston wrote: On Tuesday, July 24, 2018 at 2:22:09 PM UTC-7, wrote: On Tuesday, July 24, 2018 at 12:05:18 PM UTC-4, OHM Ω http://aviation.derosaweb.net wrote: On Tuesday, July 24, 2018 at 9:31:44 AM UTC-5, Dan Marotta wrote: In my last experimental glider I used two rather stout SPST toggle switches to control my two LiFePO4 batteries.Â* At some point of the flight I would switch the second battery on and then switch the first battery off.Â* I don't think it was really necessary given the longevity of these batteries compared with the SLAs that I used previously, I simply switched about half way through the flight so that both batteries would get some use.Â* I like John's idea with the MOSFETs. On 7/23/2018 10:43 PM, Andy Blackburn wrote: On Wednesday, June 20, 2018 at 6:27:33 AM UTC-7, OHM Ω http://aviation.derosaweb.net wrote: Andy, I have used the ideal diodes mentioned by Shaun McLaughlin (http://re-voltage.eu/ US$27 each) as I was given a pair to test with.Â* They do what they say with minuscule voltage drops across them.Â*Â* Full disclosure, I am currently using two 1N5821 Schottky diodes in my panel right now (page 74 of my presentation) - small, simple, cheap, plentiful, robust, and easy to mount. That being said - the availability of inexpensive ideal diodes has exploded in recent years mainly for use in systems like solar panel arrays.Â* See https://www.ebay.com/sch/i.html?_fro...es%29&_sacat=0. I also like the increasing range of mounting styles available allowing for placement options behind our increasingly cramped panels. John (OHM), Yup, I have one of Shaun's (on your recommendation) and some of the anti-revere-irrigation ones. I haven't installed either. My current install uses the Schleicher rotary switch to select: Battery 1, Battery 2, Battery 1+2 (through diodes), Battery 3 (tail). I use a bank of capacitors connected through a power resistor to energize the circuit when the switch is between batteries. If I had to do it again I would use ideal diodes (though as others have mentioned this is really not nearly a necessary with LiFePO4 batteries since they go through voltages below 11v quite quickly on my battery tester). I would also separate the batteries to individual switches to eliminate the switch as a single point of failure. Andy Blackburn 9B -- Dan, 5J Dan - Do you have diodes in this circuit to prevent cross-charging of the batteries? I will repeat something I said above that (without diodes) putting the batteries in parallel can cause a large current to flow from the "high" battery to the "low" battery.Â* Effectively one battery is charging the other. For dumb SLA batteries this will almost certainly blow the fuse on your batteries (you do have a fuse right at your battery's positive terminal, right??). On lithium batteries, which probably have intelligent current limiting electronics inside, this should not be an issue.Â* But notice the words "probably" and "should". YMMV.Â* Be careful out there. - John OHM Ω How much current do you project when switching from a low LiFe at 12.4 volts(pretty much done) to high at 13.7? I have been doing this switching with SLA batteries for 25 years. Switch new one on- switch old off a second or two later. Have not blown up anything yet. UH Plus one. KISS principle. Two switches and two fuses should work fine, certainly an improvement over some of the Rube Goldberg solutions proposed here. But two batteries, two fuses, and two Schottky diodes would be an improvement.Â* Perfect for everyone except jet jockeys who want more switches to flip. Finally, one properly sized battery with a fuse is probably the best solution, half the number of BMS boards to blow up.Â* Can't get much simpler than that.Â* There's a lot to be said for reducing component count. Speaking of losing the panel, Garret Willat just posted a video on FB of flying in the Czech Republic with no avionics power, which also took out his engine controller. Did have a paper map and mechanical vario. |
A Simple Question About LiFePO4 Batteries | [email protected] | Soaring | 49 | May 25th 18 04:27 PM |
LiFePO4 Batteries on sale. | [email protected] | Soaring | 20 | December 9th 15 05:34 PM |
K2 vs. StarkPower LiFePo4 batteries | Fox Two[_2_] | Soaring | 36 | April 16th 15 05:14 PM |
LiFePO4 Batteries | vontresc | Soaring | 56 | June 27th 14 07:25 PM |
LiFePO4 batteries | JS | Soaring | 26 | October 15th 12 02:51 PM |
