iGlide
Old August 3rd 18, 01:10 AM posted to rec.aviation.soaring
Default iGlide
Not sure about the altitude in a replayed flight, but uploading to OLC is really easy and you take your igc file anywhere from there. I do believe the airspace works in the basic version. The documentation isn’t great, but if you poke around a bit you’ll see how to do it. You will need to download the turnpoint file for your area from the turn point exchange.
Old August 3rd 18, 01:13 AM posted to rec.aviation.soaring
Default iGlide
Go into settings, then airspace. Select USA. That should do it.
iGlide Ben S Soaring 31 February 16th 20 04:14 AM
iGlide runner4065 Soaring 19 March 28th 16 11:12 PM
Iglide chris johnson Soaring 2 August 1st 15 03:22 PM
iGlide Mike Rinaldi Soaring 4 April 28th 15 12:48 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
