Stall spin during aero tow? Std cirrus
Old August 8th 18, 03:12 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Stall spin during aero tow? Std cirrus
On Wednesday, August 8, 2018 at 5:18:26 AM UTC-7, PGS wrote:
On Tuesday, August 7, 2018 at 10:45:24 AM UTC-4, Steve Koerner wrote:
This subject comes up every few years on RAS and that's a very good thing. Long ago there was a death on tow with a heavily watered ship that I'm pretty sure was caused by this.
I have already posted a couple times in the past about my own near death experiences I have had dangling from a slow towplane at a remarkably low stalled tow position while slamming the stick back and forth against the stops in Ventus 1 and in ASW27. When this is happening at a very low altitude (as it was), then releasing is not an option.
Several have pointed up the necessity of communicating with the tow pilot. I think it preferable to communicate in writing. Except at contests, I always make sure that the tow pilot has been handed my written towing instruction when I have water ballast. Here's a link to my little towing instruction sheet: https://goo.gl/PwVu71
Steve, you should not assume the tow planes airspeed indicator is calibrated or accurate. You might consider modifying your note to say "minimum" or "at least" and once safely on tow ask to slow down if need be.
Another way to calibrate the speed, tell the tug to tow you as he would tow the operation's SGS 2-32.
Old August 8th 18, 06:37 PM posted to rec.aviation.soaring
Dave Nadler
Just last week somebody reminded me of a 2-32 stall-spin off tow
near here (several decades ago).
Old August 8th 18, 08:42 PM posted to rec.aviation.soaring
Jonathan St. Cloud
That is why all the operators will make sure the tow pilots know it is important tow the 2-32 at the correct speed. “Tow me at the same speed as you tow the 2-32”. If anything you will ask the tug to slow down
Old August 8th 18, 09:24 PM posted to rec.aviation.soaring
kirk.stant
Not too many 2-32s outside the USA (too bad - love that glider). As far as Pawnees, expect (again, in the US) it to have an airspeed indicator in MPH (or perhaps a dual-scale ASI), so give him your tow speed in MPH, regardless of what you have in your glider. Better for him to tow you in MPH numbers on a Knots ASI than the reverse!
And if the Pawnee about to tow you in your 11 psf waterlogged glass ship has one notch of flaps down - don't hook up until he brings them up! That's only needed for 1-26s and K-13s (lets a Pawnee tow nicely at 65-70 mph) and a possible sign that the tuggie is not quite on the ball...
Pawnee statics = cockpit static, usually. Airspeed a bit lower and altitude a bit higher in my experience, but not by much (5 mph / 100 ft)
Kirk
Stall/spin and ground reference maneuvers Bill D Soaring 55 March 11th 14 04:35 PM
Improved shear/stall-spin alarms KiloKilo[_2_] Soaring 23 June 11th 13 11:55 PM
Another stall spin Jp Stewart Soaring 153 September 14th 12 07:25 PM
Stall/ Spin testing the RV-12 cavelamb himself[_4_] Home Built 3 May 14th 08 07:01 PM
Glider Stall Spin Video on YouTube ContestID67 Soaring 13 July 5th 07 08:56 AM
