Test results LiFePO4 glider batteries after 6 years
Old August 8th 18, 05:08 PM posted to rec.aviation.soaring
George Haeh
Default Test results LiFePO4 glider batteries after 6 years
I've had my K2's for about five years now. Last spring I bought a CTEK LiFePo4 charger, which has 8 stages and ran the batteries through several recharges. Each time the batteries seemed to absorb a bit more.
Last week I flew one battery for over 7 hours on two flights. The Air Glide S showed the voltage flipping between 11.9 & 12.1. Note that the Air Glide S seems to underread by about 0.6V compared to the Tasman. Poking around with probes showed no drop in voltage between the battery and the Air Glide.
Back on the charger it took over three hours to get the battery back up to float. The charger was quite warm for the 2.5 hours in stage 2.
The other battery flown for three hours charged back up in a little over an hour.
I suspect that the batteries need heavier usage than just 3-4 hours of flight before accepting a full recharge.
Old August 9th 18, 12:30 AM posted to rec.aviation.soaring
kinsell
You've got two old batteries, with two different state of charges.
Rather than speculating on some memory effect, it might be more likely
that the batteries are no longer equivalent, perhaps one has a few weak
cells and needs a bunch of balancing.
That was an interesting thread you bumped, didn't realize just how much
misinformation got crammed into that one. Someone stated that you don't
charge a LI-PO battery with a SLA charger, certainly a true statement.
Multiple people responded by saying that it's fine to charge an LFP with
a SLA charger. It's almost as if they don't know the difference. With
all the discussion about how typical BMS boards need high voltage
applied for a long period of time in order to balance cells, some people
still think the SLA charger works fine for LFP. I guess it's fine as
long as you don't care about the lifetime of your battery, and if you
don't care about getting a full charge.
Then there was another discussion about how radios supposedly last
longer with higher voltage, because someone's 37 year old radio just
died. I really don't think it would have lasted any longer no matter
what voltage was used. Similarly, radios that we use don't draw less
current with higher voltage, the only instrument in your panel that
might draw a bit less current is a transponder.
-Dave
Old August 9th 18, 06:30 AM posted to rec.aviation.soaring
2G
"the only instrument in your panel that
might draw a bit less current is a transponder"
I seriously doubt it. All modern avionics are designed to operate over a wide input voltage range; they have internal dc-dc conversion circuits that transform the supply voltage to a regulated, operating voltage. Trig, for instance, specifies an input voltage of 11 to 33 V.
Tom
Old August 9th 18, 02:13 PM posted to rec.aviation.soaring
kinsell
Tom
So does an LX9000 count as a piece of modern avionics? 12 volts
nominal, 10-16 volts min to max. How about a Becker 4201 radio? 12.4
min, 15.1 max, 13.8 nominal. There's very little avionics used in
gliders that have dc-dc converters, they're included in transponders
because you can't generate 300 watt pulses using battery voltage, you
have to step it up with a converter.
Dave
Old August 9th 18, 07:55 AM posted to rec.aviation.soaring
krasw
I installed a small coulometer (with LCD-display, available from Ebay) between my charger and battery. I can also discharge battery (with car tail light bulb as load) with coulometer. For example, before disconnecting charger I can see that charger put 3 Ah to battery. Annual test shows total capacity from 100% charge to 0%. No more guesswork about battery condition.
There would be market for full-blown panel mounted battery monitor system for gliders. One that monitors each battery charge and discharge, with built in breakers etc.
Old August 9th 18, 12:12 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Multi-chemistry chargers are sold for RC model flying that are also
suitable for checking capacity on our batteries and can handle any
chemistry that is normally used in gliders. Prices vary (of course)
depending on capabilities, but are generally reasonable unless you want
the sort of gorilla charger used by the F5x crowd. In the USA HobbyKing
would a a reasonable place to start looking.
But, none of them will fit in a glider's panel.
Martin | martin at
Gregorie | gregorie dot org
Old August 9th 18, 05:10 PM posted to rec.aviation.soaring
2G
The only one I could find specifically designed for aircraft is the MGL BAT-1 (anything else was only a voltmeter or ammeter):
http://www.mglavionics.com/BAT1.pdf
It does not have a coulometer, however. I have specified this for my new ASH31.
Tom
Old August 9th 18, 06:46 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
2G wrote on 8/9/2018 9:10 AM:
Pilots that are don't require the alarm function can find small panel mounted
volt-amp meters like these from Amazon for about $15:
- WATERWICH DC12-24V/0.1-10A Dual LED Digital Multimeter Amp Voltage Meter
- TOOGOO(R)Dual LED Digital Voltmeter Ammeter DC 0-100V 10A Panel Amp Volt Meter
I'm not suggesting those two are the best choices, but I have used similar units
that worked well.
There are panel mounted units that include amp-hour/watt-hour readings, but are
larger. I use a charger for my instrument battery that shows amp-hour/watt-hour
readings during charge, so I can see the battery did accept the expected charge.
That's be satisfactory for years, so I haven't felt the need for amp-hour readings
in the glider; generally, my current drain in-flight varies only a little.
LifePO4 batteries for motorgliders - are we there yet? Chris Soaring 13 January 9th 16 03:43 PM
Bioenno Power LiFePO4 12V Glider Batteries Paul Remde Soaring 13 April 21st 15 04:35 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
