S80- Vario/altimeter setup: Electronic compensation (internalsensors) or TE Probe?
Old August 13th 18, 04:48 PM posted to rec.aviation.soaring
Default S80- Vario/altimeter setup: Electronic compensation (internalsensors) or TE Probe?
On Monday, August 13, 2018 at 10:03:30 AM UTC-4, wrote:
My LS-8 was set-up the same way from the factory. The front static ports are for the flight instruments.
I used the boom statics for my S80.
They work very well.
There was a comment about dumping ballast and that water messing with the boom static ports. My boom static port system has four static port holes around the circumference of the boom. When I dump water I see no alteration in the display of the S80. I would imagine that is because the water does not wet all of the static ports.
I have not gone to the trouble of equalizing the tubing lengths of the static and pitot systems. I will do that by just coiling the excess pitot tubing behind the panel.
That sound like what I have - and I fly in the east, so we almost never use water ...
I will try using the boom ports - the co location as a prerequisite stopped me from trying.
WH
Lx9070 V80 and Butterfly electronic and pnuemantic compensation Jonathan St. Cloud Soaring 2 May 5th 16 06:47 PM
Non-TE probe compensation Ale.L (RL) Soaring 7 January 27th 15 03:23 PM
Westerboer Vario with electronic total energy compensation kd6veb Soaring 1 August 3rd 11 08:25 PM
Electronic versus Pneumatic compensation (conclusions) [email protected] Soaring 0 September 26th 05 05:02 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 4 September 20th 05 06:21 PM
