Perlan High Altitude Tow Plane
Old August 16th 18, 02:32 AM posted to rec.aviation.soaring
AS
Default Perlan High Altitude Tow Plane
On Monday, August 13, 2018 at 11:18:01 PM UTC-4, Frank Whiteley wrote:
http://www.reporterherald.com/lifest...s-stratosphere Arne is an SSA member and member of Colorado Soaring Association.
Here is a video of the first tow by the Grob G520 towing a G103.
https://youtu.be/q-1qBOUMfwo
There is no N-# visible on the Egrett in the video. Does anyone know what category it is registered?
Uli
'AS'
Old August 16th 18, 03:20 AM posted to rec.aviation.soaring
kinsell
Uli
'AS'
It would be the one registered in Delaware in this list:
https://registry.faa.gov/aircraftinq...ETT&PageN o=1
Old August 16th 18, 04:13 AM posted to rec.aviation.soaring
Ramy[_2_]
Typo aside, am I the only one somewhat disappointed to learn that the plan is to tow the Perlan to 50,000 feet, or I missread the article? I was kind of hoping the Perlan is capable of climbing to 90K from a reasonable tow altitude.
Ramy
Old August 16th 18, 04:53 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Ramy wrote on 8/15/2018 8:13 PM:
Ramy
My understanding is the Egret has that capability, but they don't plan to use it
routinely.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old August 16th 18, 05:21 AM posted to rec.aviation.soaring
kinsell
Ramy
Arnie told me that Perlan was having a lot of trouble climbing through a
certain altitude band (30K?). With an unheated cabin and limited
electrical power, that made if difficult to have successful missions.
I don't think they're planning on going to 50K, but yes, high fast tows
is why the Egrett was brought in. First high tow went to 40K.
-Dave
Old August 24th 18, 01:55 AM posted to rec.aviation.soaring
Ramy
What, Real Men scratch around for hours just to prove ...what?...
The fact is that Perlan was designed to fly in and study *stratospheric* wave, not tropospheric wave. These waves are rarely stacked and connected. Perlan I found such linked wave once in two years, and then set a record over 50,000 ft. Perlan II found such linked wave once in two years, and then set a record over 50,000 ft.
The hope is to do aerodynamic and atmospheric research in the stratosphere. In the winter, the tropopause (the boundary between tropo- and strato-sphere) generally descends to about 30,000 msl. It happens to be about 40,000 msl in the southern hemisphere at the moment.
The Egrett, used as a towplane, is able to reliably bring Perlan II into the lower reaches of the stratosphere in about an hour. Only in this way will the glider be a reliable research vehicle.
And such research is important: the polar night jets are poorly understood, yet are known to drive climate in some ways. It is not know what triggers stratospheric wave, and one of the hindrances to Perlan "success" is that predictive models are inaccurate simply because of human ignorance.
While it's spectacular to set altitude records, the real importance of this project is making steps toward stratospheric research in a vehicle that will not contaminate the nearby atmosphere with noise: chemical, mechanical, aerodynamic.
This is not a toy and its mission is not play.
DrDan Johnson
Old August 24th 18, 08:21 PM posted to rec.aviation.soaring
Bob Kuykendall
On that basis, wouldn't you be much better off doing your oh-so-serious research with a UAV?
--Bob K.
Old August 24th 18, 09:12 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Possible/probable reasons why Perlan 2 is the best choice:
- Perlan 2 already exists.
- There are no electric UAVs with a similar flight envelope.
- Any powered replacement has to be electric to avoid atmospheric
exhaust contamination.
- Even an electric UAV will add unwanted disturbances with its prop wake.
Martin | martin at
Gregorie | gregorie dot org
Old August 24th 18, 10:00 PM posted to rec.aviation.soaring
Bob Kuykendall
And, hey, the made production-quality wing and fuselage tooling for it, so they can make more if they want!
This isn't about electric versus unpowered. It's about the necessity of doing this with a crewed vehicle. There is nothing in any of those arguments that supports carting two humans and several hundred pounds of life-support infrastructure around the sky.
I'm sure that there are valid arguments for having humans aboard so they can respond adaptively and innovatively to any flight or scientific situation that might arise. I simply don't buy the idea that doing so is best or even lowest-cost option. I think that a UAV, or a cooperative swarm of UAVs, or even a series of balloon-dropped UAVs, could do the planned research with a risk/reward ratio about an order of magnitude better.
--Bob K.
Old August 16th 18, 03:06 PM posted to rec.aviation.soaring
Dan Marotta
Was that Gary Powers climbing into the Egrett?Â* Nah...Â* Couldn't have been.
Uli
'AS'
Dan, 5J
Perlan GLIDER ALTITUDE: 52004 ft Tom Kelley #711 Soaring 15 September 5th 17 03:54 PM
Perlan flying GLIDER ALTITUDE: 51134 ft Tom Kelley #711 Soaring 2 September 3rd 17 06:21 PM
Martin B-57 Canberra pics [19/20] - NASA High Altitude Plane.jpg (1/1) Miloch Aviation Photos 0 August 26th 16 12:34 AM
Perlan project - high wave flights Bill Daniels Soaring 2 October 20th 05 01:15 AM
High Altitude simulator accuracy in X-Plane Ghazan Haider Simulators 2 August 16th 05 06:01 PM
