On Monday, 3 September 2018 03:39:58 UTC+10, 2G wrote:
On Thursday, August 30, 2018 at 10:44:06 PM UTC-7, wrote: Watch this.....and consider your life. https://youtu.be/oYpG0HDcFsA That video claims that "the model jet engine is a scaled down version of the real thing. It is essentially the same technology that lifts enormous aircraft into the sky." This couldn't be anymore further from the truth. Watch this video and tell me that they are "essentially the same technology:" https://www.youtube.com/watch?v=VfomloUg2Gw What struck me on the models is that the most vital components, the fan and compressor blades, are manufactured out of aluminum. Aluminum is not a high temperature metal. One pilot who had multiple start failures of these jets told me that ONE problem was the clearance between the fan blades and the housing, which must be tight to begin with for the jet to work. The shear number of failures I have personally heard of convinced me that I would not a jet sustainer. Tom The reason the compressor and diffuser are aluminum is because they do not get very hot. The compressor is usually a truck turbo compressor made by Honeywell or Garrett. IIRC Honeywell bought Garrett. Yes the principles on which the small jets operate are the same as large ones although the small ones are turbojets with no fan, just a centrifugal compressor which is much less fussy about inlet flow distortion and much more robust than a small axial compressor would be to debris impact. At least one small axial compressor engine of about 27 Kg thrust has been made though.. It was intended to drive an alternator in a hybrid car to be made by Jaguar and fuel consumption was an issue hence the axial compressor to get higher pressure ratios. You could get higher pressure ratios by using a two stage centrifugal compressor (second stgae compressor needs to be steel)but nobody ever made a turbojet like this although the Rolls Royce Dart turboprop had this configuration. The small engines are pretty much small scale models of the De Havilland Goblin engine from 1943 (it was a good engine)which shared their layout of single stage centrifugal compressor and single stage axial flow turbine, the difference is the small engines have a cannular combustion chamber instead of individual burner cans. Modern turbofans use axial compressors for higher pressure ratios for better fuel economy. They operate at far higher temperatures in the hot end with actively cooled turbine blades by blowing cool air through them which comes out in many small holes. The turbine stage can operate at temperatures above the melting point of the blades. They also do things like blow ducted air around the outside of the turbine shroud to minimise clearances. In the small engines the weakness is the rear bearing which is in the turbine wheel. It is the one that gets hot. Possible solution is to not run at 100%, where the turbine temperatures are much higher than at 75% to 85%. There are now several engines in the thrust range required (around 40Kgf) made by AMT, TJ, Jetcat and BF Turbine. The BF 500 in particular is actually a 50 Kgf engine derated to 40 Kgf. It is early in the development cycle for glider use. There are only the SharkJet with an AMT Titan, The PSR system and the M&D jet on the JS gliders. One weakness is the kero start system on all these which is why fuel and vapor pressure and flash point of same is important and they are fussy on fuel. The M&D jet used to splatter fuel around. JS solution was to drill a nice hole in the bottom of the engine compartment. Latterly they have put the igniter in the bottom of the engine rather than the top and made a small improvement. I can see why. Kero or diesel can make a pretty good fire extinguisher in the right circumstances and can be difficult to get burning. There are possible solutions. Chris Esselsteyn doesn't seem to be having much trouble with the 2 x Jetcat P300 engines in his HP18 jet but jetcat have an internal igniter which seems to work well. he told me he gets essentially no excess fuel on start. He was at Oshkosh with it again this year. I suspect a large proportion of failures with the jets is poor operating procedures(dirt in fuel) and or poor/non existent inspections. The other jet that needs mention is the TJ100 engine that Bob Carlton uses and sells. That engine has a real recirculating oil system and seems excellent. Being used in the SubSonex jet kitplane too. It started life as the APU for the MiG 29. Mike |
Mike, great background and information on the small turbine world. Thank you for the in-depth and knowledgeable post. When you mention that JetCat uses an internal igniter rather than the glow plug can you explain this a bit? What is the difference and, theoretically speaking, could other jets use an igniter? Thanks again for posting.
John Seaborn |
On Monday, 3 September 2018 09:01:07 UTC+10, John Seaborn (A8) wrote:
Mike, great background and information on the small turbine world. Thank you for the in-depth and knowledgeable post. When you mention that JetCat uses an internal igniter rather than the glow plug can you explain this a bit? What is the difference and, theoretically speaking, could other jets use an igniter? Thanks again for posting. John Seaborn Hi John, Thanks. The AMT and PSR (AMT derived) engines and most other small turbines used to use a model airplane glow plug with a turn or so teased out into the breeze to ignite the propane starting gas. There was a delicate balance between getting the thing to light off by making the glowplug hot enough and glowplug life. It was difficult to know if you were going to get one start or 100 starts from a glowplug. Doesn't matter when launching a model airplane or drone. From all accounts though the gas start system was pretty good. I designed a spark unit using a modified model airplane spark plug which worked well and then kero start became available. Good for military drone operators as you can't carry pressurised inflammable gas on a C-130 etc. The AMT/M&D igniter is a silicon nitride rod with a heating coil inside it. It is a commercial part used in diesel fuel heaters etc. Fuel gets dribbled around the outside of it under no pressure so you get a vapor barrier which prevents all the fuel from heating and excess unburnt fuel falls in to the engine causing hot starts (auto shut down) or excess fuel being blown out the back of the engine. At least it isn't prone to burning out. I've never managed to find an image of the current JetCat igniter, not for lack of trying. I suspect it is a flat heated strip with fuel sprayed on to it as droplets which would seem much better. One thing I have thought of - the M&D system seems to use a pretty standard K2 12 volt nominal LiFePO4 battery. AMT specify a 4 cell LiPo pack which goes up to 16+ volts when fully charged. I think a 5 cell LiFePo4 would be better to get the heater hotter and spin the starter faster. I'm experimenting with this and a way of reducing the kero flow rate into the igniter while still having the main fuel pump start. There is only one pump which requires a certain minimum voltage to start but then produces too much flow rate into the igniter resulting in excess fuel. Mike |
On Sunday, September 2, 2018 at 6:19:29 PM UTC-7, Mike Borgelt wrote:
On Monday, 3 September 2018 09:01:07 UTC+10, John Seaborn (A8) wrote: Mike, great background and information on the small turbine world. Thank you for the in-depth and knowledgeable post. When you mention that JetCat uses an internal igniter rather than the glow plug can you explain this a bit? What is the difference and, theoretically speaking, could other jets use an igniter? Thanks again for posting. John Seaborn Hi John, Thanks. The AMT and PSR (AMT derived) engines and most other small turbines used to use a model airplane glow plug with a turn or so teased out into the breeze to ignite the propane starting gas. There was a delicate balance between getting the thing to light off by making the glowplug hot enough and glowplug life. It was difficult to know if you were going to get one start or 100 starts from a glowplug. Doesn't matter when launching a model airplane or drone. From all accounts though the gas start system was pretty good. I designed a spark unit using a modified model airplane spark plug which worked well and then kero start became available. Good for military drone operators as you can't carry pressurised inflammable gas on a C-130 etc. The AMT/M&D igniter is a silicon nitride rod with a heating coil inside it. It is a commercial part used in diesel fuel heaters etc. Fuel gets dribbled around the outside of it under no pressure so you get a vapor barrier which prevents all the fuel from heating and excess unburnt fuel falls in to the engine causing hot starts (auto shut down) or excess fuel being blown out the back of the engine. At least it isn't prone to burning out. I've never managed to find an image of the current JetCat igniter, not for lack of trying. I suspect it is a flat heated strip with fuel sprayed on to it as droplets which would seem much better. One thing I have thought of - the M&D system seems to use a pretty standard K2 12 volt nominal LiFePO4 battery. AMT specify a 4 cell LiPo pack which goes up to 16+ volts when fully charged. I think a 5 cell LiFePo4 would be better to get the heater hotter and spin the starter faster. I'm experimenting with this and a way of reducing the kero flow rate into the igniter while still having the main fuel pump start. There is only one pump which requires a certain minimum voltage to start but then produces too much flow rate into the igniter resulting in excess fuel. Mike I noticed that you did not mention the clearance issue that one pilot reported - do you not consider this to be a problem, or are you mystified? Tom |
![]() I noticed that you did not mention the clearance issue that one pilot reported - do you not consider this to be a problem, or are you mystified? Tom If I recall correctly, centrifugal compressors have larger tolerances for clearance of the rotors and housing compared to axial compressors. |
On Tuesday, September 4, 2018 at 4:32:20 PM UTC+1, WB wrote:
I noticed that you did not mention the clearance issue that one pilot reported - do you not consider this to be a problem, or are you mystified? Tom If I recall correctly, centrifugal compressors have larger tolerances for clearance of the rotors and housing compared to axial compressors. ....but IIRC in the development stages of the M&D jet JS reported that they found some cases of the engine surging after starting and this was corrected by M&D tightening up the clearance tolerances for the centrifugal compressor to the inlet casing. The jet I had certainly had very close and even fit which I looked at in my pre-flight checks as I finger spun the compressor. |
The older JetCat igniter is just a rod and always seemed to work work well on both kero and diesel. I am not sure if they changed the igniter for the newer RXi with internally mounted solenoids. |
I'm glad you mention the pump. Turbine is one thing but the pump and its settings are the key to successful starts(of course together with a good battery). The pump voltages(sometimes referred to as pump power) supplied at different start stages are critical to getting a reliable start. Too much and you get a flaming hot start, too little and it wont stay lit and restarts thereafter result in residual fuel and another hot start. Getting it just right is a tuning process(through various params in the ecu and also depends on fuel type) but is also complicated with breakin of the pump over time in the case of new pumps. So as an owner, monitoring the pump power during operation so as to monitor "pump health" is fairly important. Think we all agree clean filtered fuel is must but they can and do wear out. I've had one with 200 hundred runs overshoot on rapid throttle advance and never expected to see 6 foot of flame out the back which actually extinguished the engine. After a new pump, all was good again after a retune. |
On Thursday, 6 September 2018 01:29:45 UTC+10, wrote:
There is only one pump which requires a certain minimum voltage to start but then produces too much flow rate into the igniter resulting in excess fuel. I'm glad you mention the pump..... Thanks for that. Good information on break in of the pump. As for close clearances just contemplate the clearances in the crankshaft and bearings of a two stroke or the clearances in the cylinders. BTW your piston engine ought to melt. The fuel burns hotter than the melting point of the metal but there is a boundary layer in the gases at the surface of the metal. The origins of the M&D engine mentioned are in accordance with what I was told by someone who ought to know. Last time I looked the certification on jets for sustainer use was that it wasn't allowed to blow up or catch fire. M&D seem to handle the blow up bit by limiting the number of cycles before overhaul. HpH in the Sharkjet went the ballistic shielding route. The turbine blade of a Titan weighs about the same and moves at the same speed as a standard velocity 0.22 rifle bullet. It was fun doing ballistic shielding tests. 1 mm of 4130 dents but does not break. 8 layers of 170 gm Kevlar catches the bullet. Interesting. |
Good information on the pump. Can you expand on this a bit? What voltages are needed on the pump for a normal start on the M&D Jet? What makes sense for tuning based on fuel, jet vs. diesel? What is the best way to monitor the voltage to the pump under power?
Boyer retires - Catastrophic mission failure | Skylune | Piloting | 4 | July 9th 08 08:49 PM |
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports | BarneyFife | Piloting | 11 | December 8th 07 11:46 AM |
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports | BarneyFife | Instrument Flight Rules | 0 | December 5th 07 08:15 PM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
