Moller gets competition!
Old December 10th 03, 02:49 AM
R. Hubbell
On Sun, 7 Dec 2003 12:25:06 +0100 "Rob Turk" wrote:
Let's scrap our puny little planes, the future is he
http://www.taero.com/
Go, go Gadget Wings!
Rob
Competition to produce nothing marketable. I guess that's a form of
competition. These projects never seem to get off the ground. It's
just not gonna fly. These guys have there heads in the clouds. They're
working by the seat of their pants. (did I miss any?)
R. Hubbell
Old December 10th 03, 02:51 AM
Tim Ward
"R. Hubbell" wrote in message
news:yQvBb.29424$ZE1.619@fed1read04...
Rob
R. Hubbell
I think they're working by the clouds, and have their heads in the seat of
their pants.
Tim Ward
Old December 10th 03, 02:57 PM
Mark Hickey
their pants.
They'd better keep 'em there - sticking them up in the 300mph
slipstream like the guy in the (doctored) photo isn't a good idea at
all.
Mark Hickey
Old December 11th 03, 06:53 PM
BllFs6
Hi all...
This topic got me thinking about "aerocars" and during a night of tossing and
turning it occurred to me....
Most (if not all) aerocar "inventors" have their approach backwards....
They are trying to take a CAR and make it into a plane....
Which isnt impossible.....as long as your plane is capable of being say 750 to
1500 pounds overwieght......which means you need a REALLY big plane to absorb
that kinda fat and/or your gonna have a plane that sucks performance wise (ie
barely flies)...
And they want to take car drivers and make them into pilots.....todays drivers
expect all kinds of luxuries.....lots of room, ac, stereo, big cushy seats,
tire burning amounts of HP etc etc....which all adds way too much wieght....
And besides anything shaped like a car is still gonna bite drag wise.......
So Lets turn this around!
Lets take pilots and make them car drivers....
Any ground "vehicle" that is even a bit quiter or roomier than most small
planes would keep a pilot happy......if they had virtually ANYTHING to drive
other than a bike when they got where they were going they would be thrilled...
So, instead....lets take a plane and make it into a car.....
And it seems to me the most obvious config for that is a canard design......
Make the front canards removable or configurable so that the provide 0/negative
lift when used in "car" mode......
make the front of the canard plane "breakable" about where the the rear wings
start....and thats where your gonna put 2 "rear " wheels....
Now you have a decently areodynamic 3 wheeled motorcyle/trike.....
For such a lightwieght ground vehicle you probably only need 10hp give or take
for decent acceleration and top speeds.....
What about an engine you say?
Screw messing with the aircraft engine....which would entail all sorts of heavy
drives/clutches/transmissions/removable parts/doing scary things to your very
important aircraft engine....and just generally doing things aircraft engines
arent designed/meant to do....
Instead, lets just carry a small 2nd engine to move our chopped off front of
the plane around.......
You could use a 2 stroke ultralight engine.....one model offered is roughly
27hp and weighs about 50 lbs....it might even have enough hp/torque to drive
your "car" with just a direct drive....or at worst a 2/3 speed
transmission/redrive.....
Now, obviously this "Burtan Trike" would be a death trapp if you got hit by
another car........but so are motorcyles....and small planes when you land very
badly for that matter....
So, if you went with something like this dont you think you could keep the
weight penalty down to say 200 lbs? over a straight airplane of similiar
design? more? maybe even less?
Just some wild thoughts here...
Blll
Old December 11th 03, 07:08 PM
ET
(BllFs6) wrote in
Hi all...
tossing and turning it occurred to me....
backwards....
say 750 to 1500 pounds overwieght......which means you need a REALLY
big plane to absorb that kinda fat and/or your gonna have a plane that
sucks performance wise (ie barely flies)...
drivers expect all kinds of luxuries.....lots of room, ac, stereo, big
cushy seats, tire burning amounts of HP etc etc....which all adds way
too much wieght....
wise.......
small planes would keep a pilot happy......if they had virtually
ANYTHING to drive other than a bike when they got where they were
design......
0/negative lift when used in "car" mode......
rear wings start....and thats where your gonna put 2 "rear "
wheels....
or take for decent acceleration and top speeds.....
of heavy drives/clutches/transmissions/removable parts/doing scary
things to your very important aircraft engine....and just generally
doing things aircraft engines arent designed/meant to do....
front of the plane around.......
roughly 27hp and weighs about 50 lbs....it might even have enough
hp/torque to drive your "car" with just a direct drive....or at worst
a 2/3 speed transmission/redrive.....
hit by another car........but so are motorcyles....and small planes
when you land very badly for that matter....
the weight penalty down to say 200 lbs? over a straight airplane of
similiar design? more? maybe even less?
Blll
Ah, just blow off all that and carry one of these in the plane...
http://www.diblasi.com/home.htm ;-)
(even if it means you need to leave the wife at home to meet weight and
balance)
ET
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 04 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
