Vario Comparison
Old September 11th 18, 12:39 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Vario Comparison
On Monday, September 10, 2018 at 2:30:43 PM UTC-7, wrote:
Hi all,
I've been looking for a good electrical vario for many years. Having good knowledge in both digital signal processing and gliding I know what to look for. First, a lot of pilots can't even recognise if the vario is compensated or not, let alone if it's fast/slow or even accurate. I've conducted test like these to get the real respons from varios: https://www.youtube.com/edit?o=U&video_id=UfeGWYwVdas
I've owned the airglide and used it for about 200h. Airglide is not a good variometer, very unstable, the filtering is not done correctly. The LXnav /LXnavigation stuff I've flown with have also been quite bad. Old Zander ZS1/940 has a much better variometer. The modern stuff just haven't got the filtering or sensor precision correct. The only modern vario i've tested that was good is the westerboer vw1020: https://www.youtube.com/edit?o=U&video_id=UfeGWYwVdas
More info at my homepage: http://niklaslofgren.net/gliding/var...ariometer.html
/Niklas
Your YouTube links did not have videos.
Old September 12th 18, 02:13 PM posted to rec.aviation.soaring
Oh, sorry, here are the correct links.
Respons test: https://youtu.be/UfeGWYwVdas
vw1020 respons test: https://youtu.be/Irun92_0JWQ?t=11m16s
Aircraft comparison Jkgoblue Owning 1 November 23rd 05 10:18 PM
Vario Comparison Update Paul Remde Soaring 4 January 9th 05 08:51 PM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
Comparison of IFR simulators Chris Kurz Simulators 0 October 27th 03 10:35 AM
EMW A6 Comparison to X-15 robert arndt Military Aviation 8 October 2nd 03 02:26 AM
