AMS Flight and LS6 Upper Rudder Bushing
Old September 21st 18, 03:49 PM posted to rec.aviation.soaring
Dan M
Default AMS Flight and LS6 Upper Rudder Bushing
It's great news if they are actually supporting it and didn't go belly up.
Could the bushing be made at a local machine shop? Probably. It appears to be made of brass. It's got an offset hole, I'm not sure what the dimensions are supposed to be (or if there is supposed to be a taper) or where I'd get that from. My guess is, getting a bushing custom made at a machine shop would be quite expensive -- because anything custom made is quite expensive.
On Friday, September 21, 2018 at 10:39:21 AM UTC-4, Dan Marotta wrote:
That's great news about support for such a fine ship!
Couldn't the bushing simply be made at a local machine shop?Â* Could
you make it yourself?Â* What's the material, brass, plastic, etc.?Â*
The LS-6 is, after all, an experimental glider.
Please
read THIS about owner produced parts.Â* I think it has the
answer to your problem.
Good luck!
(The other) Dan M
On 9/21/2018 7:31 AM, Dan M wrote:
Hello,
For those that don't know, AMS Flight (www.ams-flight.si) in Slovenia owns the type certificate on the LS4 and LS6 gliders, and has been providing support for them. Unlike DG, they do not require you to pay the "LS Tax". They do not support the LS1, LS3, or LS8.
That said, I emailed them a little over a month ago and asked them for an upper rudder bushing for the LS6. They pretty quickly emailed me back asking for more information, and I responded. That was the last I heard of them. I'm wondering if 1) they just don't like me, 2) they are on some sort of extended European vacation, 3) they are hideously backed up from European vacation, or 4) the folded?
And, I'm still looking for the bushing. Does anyone know of a source in the US (or elsewhere, preferably other than DG)?
dan
Dan, 5J
Old September 21st 18, 04:21 PM posted to rec.aviation.soaring
Dan Marotta
One of the acceptable methods for making the part was simply to hand the
old part to someone with the tools and abilities and asking him to make
one of these.Â* Your local EAA chapter would also be a place to get the
part made.Â* Most home builders will perform such a simple task for no
charge simply for the pleasure of keeping an aircraft flying.
Please
Good luck!
(The other) Dan M
Hello,
dan
Dan, 5J
Dan, 5J
Antonov An-124 Ruslan pics 2 [08/12] - forward part of the upper crew rest area behind the flight deck AN124-32.jpg (1/1) Miloch Aviation Photos 0 February 4th 18 10:11 AM
MS Flight simulator problem: rudder over reacting SilkB Simulators 10 July 23rd 07 03:44 AM
Flight Sim rudder pedals. news.ozemail.com.au Simulators 5 May 22nd 06 11:33 PM
good joystick/rudder/throttle choices for MS Flight Sim 2004 on XP [email protected] Simulators 5 September 3rd 05 10:29 AM
Value of rudder for MS Flight Simulator Darrell Criswell Simulators 10 January 6th 05 02:41 PM
