Help identifying a wing rigger
Old September 25th 18, 12:49 AM posted to rec.aviation.soaring
Valentin Mayamsin
Default Help identifying a wing rigger
I don't remember any identification labels on the rigger, I'll double check that. The issue is not the leading edge shape. The rigger is so wide I can't clamp the wing safely enough. And when I rotate wing it doesn't stay rotated under its own weight, meaning the pivot point should be closer to the leading edge. And also I used another Cobra rigger which was a bit smaller than this and fitted wing better.
Old September 25th 18, 03:54 PM posted to rec.aviation.soaring
You can cut the sliding arm that secures the trailing edge so that it fits a smaller cord wing. When rotated, the wing rests on an adjustable stop that is set to the proper angle for insertion into the fuselage.
Hope this helps,
JJ
Looking for a wing rigger for an asw 20 Marcin S Soaring 1 July 10th 17 02:21 AM
Ka6 wing rigger James Koper Soaring 2 June 22nd 17 03:23 PM
Wing Rigger Dan Marotta Soaring 2 September 3rd 16 02:54 PM
Wing Rigger FS Ron Gleason Soaring 2 December 5th 13 05:36 PM
Looking for a used wing rigger / one man rigger .... [email protected] Soaring 0 November 6th 13 06:02 PM
