At 15:17 05 October 2018, Dan Marotta wrote:
You /_can_/ solder wires into crimp pins.Â* Tin the wire first and use care - not too much solder. On 10/4/2018 10:21 PM, OHM Ω http://aviation.derosaweb.net wrote: The connector may not be listed on the Cumulus-Soaring web site. But I have bought the connectors through Paul before so I believe he stocks them. Drop him an email. Unsure what you mean by high density versus regular pins. Do you mean HD = triple row of pins like a laptop VGA connector? The Becker connector is a double row of 25 pins. I cannot tell if the connector linked by Ross from Conrad.com has crimp type pins or solder type pins. - John OHM Ω -- Dan, 5J It is a bog-standard DB25 25-pin connector as used to be used for RS232 PC connection. The pin-out can be found in the Installation Manual (https://www.cumulus-soaring.com/beck...201-Manual.pdf) |
On Friday, October 5, 2018 at 11:30:05 AM UTC-5, Tim Newport-Peace wrote:
At 15:17 05 October 2018, Dan Marotta wrote: You /_can_/ solder wires into crimp pins.Â* Tin the wire first and use care - not too much solder. On 10/4/2018 10:21 PM, OHM Ω http://aviation.derosaweb.net wrote: The connector may not be listed on the Cumulus-Soaring web site. But I have bought the connectors through Paul before so I believe he stocks them. Drop him an email. Unsure what you mean by high density versus regular pins. Do you mean HD = triple row of pins like a laptop VGA connector? The Becker connector is a double row of 25 pins. I cannot tell if the connector linked by Ross from Conrad.com has crimp type pins or solder type pins. - John OHM Ω -- Dan, 5J It is a bog-standard DB25 25-pin connector as used to be used for RS232 PC connection. The pin-out can be found in the Installation Manual (https://www.cumulus-soaring.com/beck...201-Manual.pdf) Tim, As you said the d-sub connector (and shell) are about as common as dirt. But one way or another you need to securely attach the connector to the radio or risk things wiggling loose at an inopportune moment. Thus John Foster needing this Becker latch thingy. The sliding latch arrangement used on Becker radios is not something I had seen prior to working with non-US avionics. FYI - Filser/Dittel radios have a yet another type of sliding latch arrangement. What I commonly find on US equipment (and Australian Microaire radios) is that the connector shell has a captive screw which engages into the equipment's (radio's) matching threaded insert (called an "SAE 4-40 jack socket screw"). This "US" system is very (more?) secure but it is not as easy to engage in tight spaces as the simple "Euro" sliding latch. This "US" SAE 4-40 screw system will not work with Becker/Filser/Dittel radios unless their sliding latch system is replaced with a threaded insert (and the radio's hardware is metric). Why hasn't the US gone metric? Hmmmmm. - John OHM Ω |
FS: 5 Becker 4201 + 1 Becker 3201 + 1 Dittel FSG5 Handheld | Ross[_3_] | Soaring | 10 | April 4th 18 04:36 PM |
FS: 4 Becker 4201 Radio | Ross[_3_] | Soaring | 3 | May 24th 17 09:19 PM |
FS: Becker 4201 5 Available | Ross[_3_] | Soaring | 6 | February 28th 17 06:56 AM |
FS: Becker 4201 | Romeozulu | Soaring | 0 | March 7th 14 11:21 AM |
FS: Becker AR 4201 | Don[_4_] | Soaring | 0 | September 19th 12 05:16 PM |
